guy i work with has a two ball scuppers mounted in the bilge through the transom. he has plugs that fit so he can plug them off if needed, but he says that if he takes a wave any water in the boat gets sucked out when he is moving by the prop. kinda neat idea just not sure how well it would work and not sure i like the idea of any hole in the boat bieng below the water line
We have always put our plugs on the inside of the bilge on our garboard drain. This would allow us to pull the plug from the inside when we on plane to allow water to drain out. One hole below the water line is good enough for me!!! LOL!!
If you need an extra set of hands on setting the motor or anything like that kracker let me know, i live off of rosemont and can lend a quick hand if needed from time to time.
thanks on the scupper info is that an open invite on stopping by and checking out the boat
I increased the diameter of the two drains on my splashwell and added the one-way scuppers. After one trip, I decided to remove the rubber flaps because they seemed to impede the draining process. When I'm anchored, water runs in and out of my splashwell, but it doesn't seem to cause any problems. With a 20" transom, the water is gonna get in there regardless, and I'd rather have it drain quickly than trickle through the flapper valve. This was the best pic I could find of it.
