repairing some holes in the console cut my ply to fit then glued the in with a resin woodflour mix. They tightened up solid as a rock.
Here is the transom configuration im gonna go with. I realize you all want me to put a 25" transom on this boat, I just can't afford to buy a new 25" inch motor when i have 2 perfectly running 135hp's. So to get the best of both worlds I'm gonna set my transom up like this with a 20" inch transom and then glass in a sump well with a wall kinda like this. Any opinions?
Advice takes all forms.. You got a lot of glassing to do. Transom, Stringers then sole. I like the idea of a nice splashwell on 20" transoms. The factory thought so too. Your V should sit high in the water with the 135 so no big deal.
well today is the day that I install and glass my new transom!!!!!! Im sitting here drinking some coffe waiting for the temp to come up, Its suppose to be 65 here in va beach today. I will take plenty of pictures and document all stages. im gonna be using the allthread method drilling holes through the outer skin and through the core and tighten them down to clamp core and glue them together at once. and a thickened resin between core layer and outer skin and core with a 1/4 inch knotch trowel to distribute thickened resin on the surfaces. Wish me luck fellas!!!!![]()
good work i need to do the same thing excect on an inboard and the floor from 1foot in front of the motor cover back this post helped alot[/
Mike where in Chesapeake do you live? Have you started your repair yet?
