I am using 3/4 A/C plywood with two coats of poly resin to seal it. After I install the plywood stringers into the existing cavity, I will laminate with 1708 and cap the top off with CSM.
I will be doing most of this work tomorrow so I will post some photos.
While you are in the bilge area,providing you transom is good you may want to cut a mousehole and fill with resin and 1/4 chopped strand around the garboard plug,then redrill for a new garboard plug,leave the outer layer of the transom glass in place and fill from the inside,this will increase the life of you transom.
http://www.westsystem.com/ss/assets/HowTo-Publications/Fiberglass-Boat-Repair-and-Maintenance.pdf
look through this book its short and has a lot of great ideas and techniques. you can pick up a hard copy for easy reference. it tends to promote west brand materials, but the ideas are universall
most were made in the sarasota plant. gotta remember, these hulls are 20 to 30 years old, plus the materials & techniques were still evolving.
when i cut out & replaced my deck, i bonded a 1/2 wooden tab to the underside of the lip like a shelf around the cavity. i then cut out a piece of 1/2 ply to fit the hole, then glassed over & faired to the original edge. this left the everything flush on the deck.
We have a leaning post, centerconsole and t-top and want more thickness in our wood. Do you think we are overkilling on thickness or does it sound like increasing makes sense with our deck variables?
I am almost ready for the floor which will be 3/4" A/C or 3/4" birch from Lowes. About the same price. Not sure if birch is much heaver or not.
