Making a bracket
i've often wondered why some doesn't make a bracket that would plug the I/O hole, and use the existing bolt holes( probably add a few extra), seems like a good idea, I guess back to that whole liability thing
I fixed my hole different then that, I wish we were all doing pic's back then so I would have taken pic of the work. :'(
But what I did is left the outside skin alone, I went on the inside and squared off the hole, and added two 3/4 pieces of ply, and glassed it all in.
Then went to the out side and just glassed matt in layers till I built it out to the same level as the rest.
My crazy thought at the time is if there was any pull form the out side the plug I made was bigger on the inside and never fit out the hole it the transom.
But after a few years of watching and learning, I know now that was never going to happen.
Good work BS!!
I should have thought about a Xmas tree holder and block when I did mine!!
Looks good!!
I was going to call you today but I was busy, good thing I didn't by the look of the pic's!
Hammer I stuck it on with 5200 so it'll never come off :)
Here's a few pics of the boat with the motor mounted.
Getting real close now.
I decided to go with the old verticle front half 1979 merc v200, 3wire trim setup, 2:1 ratio gears, and a newer cowling :) instead of the 2.0L 150 . . . I'll try them both at some point and compare, but the 200 is on first.
Fuel tank was a lucky find at the local marine salvage stop. It's 35 gallons 23x7.5x48 for $90 . . . any bigger and it wouldn't have fit. I actually had to grind the lip on fuel hatch opening for it to fit.
Excellent Job Shrimp. You sure you still dont want that free air ticket to Delaware in June. I have a list of things you could build me. LOL. ;D
