Hammer's transom Rebuild
Anyone ever use West system for bonding wood. I used it with cloth and had no problems, just a bit skepical on how strong it really is when it comes to bonding wood to teh fiberglass skin.
Might it be appropriate to put a layer of 6oz cloth between the plywood sheets? THat's what I had in mind, but I'm certainly no expert...
Dont know, thought I could bond both pieces of wood together ??? ???
Guess I'm gonna have to shoot down to West Marine for those free booklets. :-/
When I fixed the hole in my boat for the bracket I put cloth between the two pieces of ply. But like air I am no excpert either. But it is solid as a rock!!
I also used some screws to hold all toghter, after it was dry I took them out, did not want anything to rust in there.
You are doing a good job for a first timer!!
you don't want to leave those screws in the transom and you should have placed a layer of glass between the wood. then once it dried ground the glass to be rough and wet out then wet outthe second layer of wood then clamped in the second layer. then glass it in with 2 to 3 layers of glass
Thanks MJ and SKOOL, so I guess I will add in a sheet of cloth, let dry..grind..wet down along with second piece of wood and then clamp down...correct. ??? ;)
Need more West System. Gonna go beg at the boat yard in the morning.
to late to glass now cause youhave resined now just grind the resin you put on the first layer to rough up wet out and wet out the second layer and clamp on without glass between.
Good to know this. I didnt think I needed cloth between the wood, as if how frayed was bonding in the wood to his skin of his fuel tank cover.
SKOOL, ship me some resin brother. ;)
Skools, correct me if I'm wrong, but the ideal method would go something like this...using slow cure hardener:
1. Scuff the inside of the outer skin.
2. Wet out a layer of cloth
3. Sheet of ply
4. Layer of Cloth
5. Second sheet of ply
6. Clamp the hell out of it ;D
Steps 2-6 could all be done in one shot to make for the best bond.
7. Scuff the last sheet of ply and lay up 3 layers of glass for the inner skin.
8. Have a frosty
NO loss Hammer....scuff the heck out of what you layed up yesterday, smear a mess of resin on there and go at it ;D You'll have a good bond, then glass it all in when done. It's not gonna come out of there in your lifetime ;D
Look at it like this....your making a 1.5" sheet of ply....and I gaurantee that the west epoxy bonds better than whatever glue they use to make the ply.... ;)
Just scuff it all up good!! wet it add cloth and next piece of ply, clamp or screw toghter!
Will never come apart in the next 10 years and it won't be yours!!
Remeber to take out the screws!!
right on Air except you don't need a layer of cloth between the outer skin and the wood. best is to do as i did for my Sea Ox i called boat manufactors asking where they buy their transom wood cause todays boats are built with 1 layer of ply wood that's 2 in thick. i bought a 40 layer 2" thick 5 x 10 sheet from a place in Greensboro NC for $98 and cut my own transom. this is where Parker and Grady buy their transoms. Itis kill dried treated. If you can buy treated that was killed afterwards it is best but higher.
Cloth, no cloth, cloth, no cloth. AHHHHH :-X :-X :-X
Well I sanded down the inner wood today as you guys suggested and went to town. I did wet down two scrap pieces of wood last night and they were bonded for life. Made me wonder if I realy needed cloth or not between the wood. Well I went ahead and added in a shet of cloth. With the cooler temps, it seemed that I had some longer working time. Smoking crack still helped though. :-X and I worked quick.
And here are some pix for all you pix HO's "Air". ;D
Hit the inside with the power grinder to scuff her up.
Cutting out my second piece.
Wetting in some cloth. Hope the cloth works. ??? ???
Skool is right about teh camera. it was sticking to my fingers. :o
Ahh, I did it, gotthe second piece in.
What a relief, I did it. 1.5 transom installed. ;D ;D
Screwed, glued and I got tattooed falling out of teh boat and landing on all my junk lying on the ground. :'(
