From what I have heard you CAN NOT Pour that stuff on the wood, you must remove all wood first! I have heard, I have never used the stuff myself.
I could be wrong, but I thought resin wouldn't stick to pressure treated.
Figured I would say something before we found out the hard way.
Hate to say it, but I thought the same thing. Hope I'm wrong...
It normally doesn't due to the moisture content. These are kiln dried, that's the pic of the yellow moisture tag.
Good article
http://www.glen-l.com/wood-plywood/boatbuilding-plywood.html
Ahhh....cool. You did your homework. Smart move. Some good data there. Thanks![]()
Must have had to go to Riverside! Quite the marine lumberyard. Biloxi has a good yard too.
was there a motor on that transomI was able to work on the V today. I figured I would take a break to eat and post progress.
It looks like the guy that fixed the transom before shreck owned it originally just added rover woven to the transom and made some kind of brace system. I say that because all of the rest of the wood is rotten really bad. It's coming out really easy and I should be able to grind off the rest.
I am going to use this piece after I clean it up as backing when I pour my Arjay. A lot cheaper than coosa.
wow that looks like a lot of work long as you keep her alive :money:was there a motor on that transom
Lotta work goin' on there..but it'll all be worth it when ya getter done..turns out Wellcraft didn't do such a great job on their stringers, etc...but like said, they probably didn't envision us hangin' on to 'em 30-40 years later either...![]()
