Can't wait to hear how your Bennets work out as I plan on doing the same by spring. My V came with a set of Smart Tabs that I recently removed while doing a transom clean up and bottom stripping. Good luck with your install![]()
i am not worried about sealing up the hole, it's what i'll find when i drill, the dreaded worm dirt or a steady drip drip drip...
Go ahead, Phat...there's plenty of BITE in the outter layer of glass to hold it all in place...and believe me it'll all be worth it once yer 'TABBIN'...![]()
Now the tabs are installed, pump mounted, and the tubes connected.
Next the switch and wiring, then done. Slow installation.......like turtle
Nope...sorry...after switch and wiring comes filling w/fluid and priming the system up...then done...![]()
I had M120's on my V, probably the best mod you can do. Congrats.
It was a pain to get my tabs bled! they ended up bleeding out by use so make sure you keep eye on the tank for a bit to keep filling up when low, after they are set i have not used a drop of fluid in 3 years!
Good post BGreene. Congrats on the tabs.
I'm about to buy and install M120's on my Hydra. For me, it's a pricey modification, but I've heard so many good things about them, I feel compelled to go for it.
Any pics of your install?
Bygracealone
That said, it's sometimes even more helpful to see it done by regular folks like you and me![]()
I would show you mine, but there is nothing regular about me, lol!!
I have no pics of mine any way, and they are on the Sea Ox.
