Floor replacement
Just bought a 1978 V-20, inline 250/6cyl. with some soft spots on the floor, I will be cutting it out and replacing it. I will take lots of before/during/after pictures to share with everyone.
I'm new to this forum but looking forward to being part of it.
Welcome and glad you posted. Lots of floors have been rebuilt here. Good luck with the project and as we always say... post some pics!
Hi NormanXanders
Welcome to the site. Floors and transoms seem to be the speciality of the crew here, so you're in good company. As Awthaker just said, make sure you post lots of pics. For three reasons:
) we love boat porn here.
2) If you're doing something wrong and we see it we can correct it before a huge ($$$) mistake is made.
3) If you're doing something we havent seen before and it's good then we get to learn.
In all cases , once again, welcome!! :beer:
Need your help please..
Ok...here are some pics......ran into a issue that I need advice on, under the fuel tank I found that the fiberglass covering the spine was very flexible I opened up a small hole to look at it, there is moisture in there and the wood is soft on the top side. I checked the rest of the spine from there back to motor and it all seems very hard or just the fiberglass is hard, I never cut anymore glass to really look at it was hoping it was ok based on the fact that it is not loose like it is under tank...
Can part of the spine be replaced as long as its braced and attached to the other cut ends correctly?
I have some of the beginning pics, I will take more of the spine tomorrow to show...
Well, it turned out better then I thought after I got the fuel tank removed, only one spot on the keel board about six inches long and maybe 1/8 inch deep into the board....scraped all that off and ready for new glass....
Hey Destroyer, have a Q for you....when you installed the new floor did you leave a ledge around the outside edge of the floor bottom? and did you lay your wood on top of that edge and fasten down? I guess what I'm asking is how did you attach it down? I have my own ideas but wanted your advice....
More pictures...
Its getting very close to being done....
Things are getting better
Got the first coat of get coat in this evening.....next coat tomorrow with the sand in it for a non-skid service...
looks good, i had to replace the deck in the forward part of mine. i left a lip like you did and attached a strip under it and laid the new deck flush with the old deck. i only had to replace half, so i needed to keep the deck the same level.
Norman, I'm sorry, somehow I missed this post until now.. yes, I left a ledge around the outside and eventually fastened to that. However, I scraped all the old wood off the bottom of the fiberglass floor, glued new wood to the bottom and then glassed over the whole thing to encapsulate the wood so it won't rot any more. Then I turned the deck back right side up, layed it on the ledge and screwed and glued it down, then foamed all the cavities that I had cut the water saturated foam out of up to the bottom of the new deck for added strength, then glassed all the holes and seams, sanded that, then sprayed bed liner over the whole thing for a finished water and blood proof top coating.
Your deck project is looking awesome! Well done!!! I hope you're as happy with yours as I am with mine. :clap::clap:
The finished product....
Sorry its been so long since my last reply....had a illness in my family to take care of first...but here is the pics of the outcome of my boat and I want to thank everyone of you for your much needed help with this project...
