the daydreamer
i went to put fuel in boat toay with the boat on my lift. i saw some oil on the water under the stern. i first thought it was coming from my outboard hyd steering cyl,as i knew it has a slow leak and have ordered seal kit for it.lookin futher i saw green 2 cyl oil on top of the lower unit cavataion
plate. i had a leak last year and replaced the hose from the plastic juction plate to the vro,it seamed to fix it well guess not.it is not alot but it worrys me. will look at junction fri. any thoughts?the motor has been trimed all the down while it has been on the boat lift.question is will it hurt to run it as long as oil tank full?seems to leak more after sitting from what i can tell. any thoughts would be helpful!any johnson gods out there.
