Whats The Trick
For all those bottom painters out there. So whats the trick to finding your waterline mark when applying bottom. While at the boat yard yesturday, a few boaters were saying how I should "still" bottom paint my hull and paint all the way up to the pin striping. But the water line doeasnt go as high as the pin striping. If I did bottom paint he, I would prefer to have the hull anti-foul paint right at the water. So there's gotta be a way to figure out your water line and also get a straight even line. Will I be the only guy out the trying to Chaulk a line evenly all the way around my boat ??? ;D ;D
Hammer...is your boat gonna spend a lotta time(stored) in the water, tied at a dock...or will it spend most time on trailer??...if most time on trailer, there's really no reason to bottom paint, unless I'm missin' something... ;)...
I can just see you in the boat at the slip hanging over the sides drawing a line! Then he gets it out and "what a minute...its higher now." ;D
Reel, boat will be on the trailer most of te time. What I want to do is dewax te entire hull, do all the repairs, add a coat of Interlux Interprotect 2001E and repaint the hull white.
Being a bit pressured to just paint the hull with antifoul. I guess you can apply it in lower temps, then waiting for warmer temps to paint.
Think I'm against the clock here. Te boat was lifted off the trailer and placed on 3ft. jacks. This was all done will no charge involved, but the owner doesnt want the boat sitting in his boat yard forever either for free.
I could simply do the hull repairs and spot paint, but figured this was the best time to knock out all of the hull work since she is on jack stands.
Lord....or Stinky, please send me some warm weather !!
is your boat bottom coated currently? if not don't bottom coat it. That stuff's good for 24/25 ft boats and up due to they stay in the water more usually. This is your boat right?
Don't bottom coat that boat it's a Virgin Hull!!!
If I had a Naked bottom like your boat I would NEVER NEVER paint it!!!
That is like painting it pink or something!
If it is going to stay on a trailer or rack system you don't want it or need it!!
My boat has 20 coats of crap on it and I am not ready to deal with the striping of it. But when I do get it done it will stay white!
We have had this talk here before, there is a paint you can put on there that will look great and will last like iron, Do a search on bottom paint here I am sure you will find it.
But unless you keeping the boat in the water 24/7 don't get pushed into something!!
I second (or third) that! Don't do it! I have a friend that keeps his on the trailer. First thing he did was bottom paint his virgin hull. Then he was trying to figure out how to get water line stains off the side of the hull just above the water line. Some guy online said, "muriatic acid should take it right off". Well, he was right, but it also took off his new bottom paint :o
78 and sunny today, I actually broke a sweat while working outside on the tractor. ::)
Sure, be jealous now, but in July and August when it is 98 with 100% humidity I will be begging yall for relief from this preasure cooker called Mobile!!! :o
Because I have access to an inexpensive slip ($210.00 / year), a free ramp, and a trailer, I keep my boat in the water most weekends from May to Nov. and during the week the boat usually stays on the trailer. My boat has never been painted, and I plan to keep it that way. Paint is just extra work. Don't do it just cause you can. Only do it if you have to.
So, would it be wise to use muriatic acid to strip bottom paint? My V has bottom paint and I plan on removing it when I get the time.
My 84 Wellcraft 248 was a virgin hull. I wish I had never put that stuff on her. She looks so much better without out and it turned out that even though I had a slip, because of motor replacements, she was on a trailer most of the time anyway :'(
HAMMER...PLEASE DON'T paint that hull...there's NO USE IN IT...you're spendin' $$$ you don't have to, settin' up a maintenance issue you don't have to...SLOWIN' your top-end down...people paint their hulls because they spend most or all the time in the water and THEY HAVE TO DO IT!!...You DON'T have to....Dodge this bullet... ;)...
Yeah, I dont want to paint the hull with anti-foul either. Its a big thing here I guess with all the other boats in the boat yard. Just wanna do all the hull repairs sealer her and then repaint the hull white. Thats if the weather warms up. Running against the clock here with the boat yard, Boat was lifted and stacked for free. Thinking I might be able to keep the boat at the yard for 3-weeks then it will start costing me.
Here is the boat on jacks now. Plenty of room to work on the dings, scrapes and two gouges.
The No Paint wins the vote!!
So if you paint now, you will have to stand against the wall while each member paints you!!
I am going to make you look like a Smurf and have my way with you! ;D
