Am sure this has happened to someone, but when you trailer your boat and fuel it up you have to watch that the attendant don't put the gas nozzle in that rod holder. Oh want a terrible thought.![]()
I am all for saving money, but you've got a beautiful boat. Spend the money to get the nice rubber gaskets. I've had them on mine for 6 years and they still look and work like the day I got them. They are fairly visible, so putting a cheap but effective alternative like rubber balls or duct tape isn't worth it.
Not sure I can get to them since I re did the side rod holder sections and re installed to be fairly permanent......
I've just been looking for the right size plug but haven't found it yet, thanks all.
Today I opened up the side panels and found that the rod holders DID have a rubber flange on the bottom of each holder.
Only issue was - the small ( 1/4" ) hole at the bottom of each flange.
Anyway, went to Home Depot, got plumbers caps wiith clamp and installed.
Done.
Ha!.... Destroyer you're funny!![]()
Its a boat, it gets wet! I never worried about it!! Of coarse this is from a guy that saw a huge black spot on his boat once, went over to see what it was, and it flew away! It was a swarm of flys on some old bait! The only cleaner or wax my boats have ever seen was a bottle of bleach from time to time!
LOL well thank you..![]()
But this time I was being serious. I use the same setup on my V, which is Greenies sister ship (both 96 V21s). And yes, I carry a turkey baster on my boat to suction out the water from the rod holders. It works great. Eventually the rod holders fill with water from spray, slop, washing, whatever... and since the bottoms of the holders have a solid cap on them to prevent any water from getting into the hold and the foam down there I needed a way to get the water out of the rod holders. A turkey baster works perfectly... it's long, slim and cheap and fits right down to the bottom of the holders.. a couple squeezes and you're done.
