Water in gas
Blu_Lunch
I have been reading the new formulation of gas with the ethanol will attract moisture in the gas. So when we got home from a ride today to see if the over heat problem was fixed, I pulled the filter assembly to see if there was any water I have a Radcor filter/separator with the clear bottom and drain and it was nearly full and there was about 8 oz of water. The boat console is covered when not in use so it won't get wet the filler is behind the windshield. We emptied the tank when I had the carbs rebuilt in July and we have put 40 gallons of gas in and we are down to a 1/8 tank now about 8 gallons or so. So where the @#^%@# is the water coming from? The atmosphere via the vent? Is there some sort of 2 stroke dry gas that is safe?
Most of our marinas on the Georgia coast are selling ethanol free fuel. It is 89octane and smells like real gas used to smell.
I also know of 2 fuel pumps in the county that sell the Marine Fuel and I'm using it for all the 2cycle stuff we have, besides the boat.
BP is the one selling it as "89octane Marine Fuel".
I'm not sure where all they are selling it at.
I had the same problem. I got so tired of the water in the fuel and the carb problems, that I empty`ed the main tank and now use portable "red plastic" gas tanks, and get the gas from a gas station on the highway, not the Marina. Since that, I got rid of that problem for good.
Blu,
I also had the same issues with water in the fuel. I was told by my mechanic that the water comes from condensation from Ethenol in the tanks. So I use Startron also like Steplift stated, and for me it seems to work great. I also changed my fueling habits by using 5 gallon gas containers to refuel with and fill both tanks at home instead of filling up at different stations on the road. It's a pain at times, but now I know my 50:1 mix is spot on always and I add 1/2 oz. Startron to every 5 gallons I mix, 1 full ounce for every 5 gallons when stored during winter. Plus I also add Sea Foam as per instructions state along with Marine Stabil, and my old 1984 Johnson runs outstanding. Since I have been doing the fuleing this way my water issues seem to have vanished. My mechanic told me whatever I am doing just keep doing it because it's working great. It's one heck of a cocktail/potion but I do know it works for me so I am sticking with it for now until they do something with the Ethenol issues.
Great information, the water was driving me crazy, I'm off to get some Startron for the gas. I wonder how many cars are going to have frozen gas lines this winter?.............
I hear ya Shawsee, I've gotten religous about my fueling/maintenance habits as well. I dump my filters regularly. I think that is what got me in trouble before with trash in my carbs. I wasn't dumping the inline filter on the motor regularly. Now I dump it before every outing and 9 times out of 10 there are teeny bits of trash in there.
:cry:
Maybe its the vents
Hi Blu,
Somewheres on this site someone pointed out that some of the vents are vulnerable to infiltration by water. The kind that sit below the rub rail can get water in them. Depending on how directly the tube goes to the vent, you could get water, but probably not so much as you noted. Some folks have moved the vent to a drier location, others have solved the issue--if that's your issue--by putting a small clamshell fitting over the vent itself. Good luck. Good thing you had the racor separator.
Thanks I put the Startron in today and ran it on the muffs ...let see what happens
drbabe I believe I saw your boat a few years ago in the Tri city plaza in Vernon....
Pepe looks familiar.....
Blu - On my buddy's new boat he was getting lots of water in the gas - more than you - and the dealer kept passing it off as ethanol. Finally the dealer found that he was missing the black rubber o-ring on his filler cap which they said was the problem. I can't imagine it let that much water in but he has not had a drop of water since.......I'm not sure if all filler caps have o-rings but might be worth a quick look.
Before that he had a ton of water getting in the hull. They found that his drain plug housing was not sealed properly.
Boy, I tell ya, these brand new boats are waaaaaay over-rated! I'll take my 15 y. o. boat over new any day!!
Pain in the gas
I'll look in there morning, but the console is always covered and there is a top on the boat .............thanks
That mighta coulda been my boat...
Hey Blu,
That could have been her. I bought her last year off a guy in West Hartford. He had too many toys. I think she was around for only a couple years before that; it's a Florida boat that came up sometime after 2004. I keep her out at my mother's on Cape Cod (Woods Hole). When I first bought her I posted some pix and someone said they'd never seen the teal striping and details. I don't know. It's clear that her transom was redone, as was a lot of her both inside and out. The stripes and stickers were so cherry it makes me wonder if someone had all that done special.
Hey Blu,
Mine came from a guy in Kensington one street over from the Rockcat's Stadium I found her on a ad in Outboard Exchange board in his shop in Waterford...........
It's definetly the eythenol. It's my understanding that since the vent system for a boat is different from a car the oxygen reacts with the eythenol and breaks it down faster, and water is a by-product. I've seen this a lot the past couple of years. No marinas here sell eythenol gas and there is only one mainland that sells E-Free. The only problems have been from the smaller boat guys that bring the jerry cans to fill up, ie-me!! Luckily, with the old Merc, I pretty much burn through it anyway, allthough I have recently started having some slight issues with idling and what-not.
Haven't read up enough on thie ethanol issue but it sounds like it may be worth refueling at marina with ethanol free gas even if it costs more?
Ethanol Question
I know this is probably going to sound stupid, but how do you tell if the gas has ethanol in it? At all of the stations I check all over the pumps looking for some kind of sign if the gas has ethanol, and only found one station that had a little yellow sticker on one of the pumps that said "may contain up to % ethanol additive" I have not seen this label on any other pumps.....If I ask the attendant inside, they have no clue what I'm talking about...What's ehtanol?....We only have gas..........
Is it just in my area or is it like this in other areas??
:head::head::head::head::head: Maybe I'll make this a new post......
Rabbit, they pretty much all have it. In SC they are required by law to post a sign on the pump. In NC, not so. I used to think I could get e free gas in NC before going to the beach until I learned about the law and asked around. It sucks but the good news is there are stations out there who have e free gas. You just have to find them.
HI guys,
Dont post much here but I am a regular lurker, I have a 1980 Formula 20 ft Cuddy with a 470 I/O, New floors, Stringers, Bulkheads and Fuel Tank, so I can relate to the V-20, and for the first time in my life I also had some E-10 problems. Check out the link below for some interesting info on E-10.
Thanks,
Butch
http://www.isleofpalmsmarine.com/
