wanted
JOEY
I just baught a boat and i need a head for my motor aq130c/270 dont know were to get one im not rich but i want to get on the water, can anyone help me out or point me in the right direction? Joey 360 609 0712 thanks
Joey, we need to know some things. Like the make, horsepower, and year of the motor. Model numbers will help also.
Additionally, while I don't think there are any here that would take advantage of you, as a rule of thumb NEVER post your telephone number in ANY forum online. There are lots of people that read these forums that are not members, and you just never know... be safe my friend.
thats a Volvo AQ 130 4 cylinder he's needing. Check with a local Volvo car mechanic, I'm not 100% sure, but I belive they used the same heads on some Volvo cars, you might be able to find one in a junkyard. I know I don't have any around here worth having
I think the parts off of a 240 series car motor will fit but I do not know if the head has any effect on the compression. If your still running points
you should replace them with a Pertronix electronic module. Good luck.
AQ130A: Used with the 100 and 250 series drive, ran 9.5:1 compression ratio and used Stromberg carbs. Rated at 130 hp.
AQ130B: Same as above but ran 8.4:1 compression ratio. Rated at 115 hp.
AQ130C: Used with the 250 and 270 series drive, ran 9.5:1 compression ratio and used Solex 44PA1 carbs. Rated at 130 hp.
AQ130D: Used with the 280 series drive, ran 9.0:1 compression ratio and used Solex 44PA2 carbs. Rated at 130 hp.
