WANTED!!! rodboxes
  • Thread starter Thread starter fishbonejr
  • Start date Start date
Stupid question of the day for all you bracket guys.
How do you mark the holes from the bracket to where you are gonna drill through the transom. Does the bracket come with a template to mark the holes on the stern ?? It something you cant do by simply holding the bracket up with one arm flush and level and marking the holes out.  ;D
Is the bracket threaded ?, seen one company that has the bracket threaded, you thread bolts to the bracket first, then bolt/nut the bracket on to the transom.
BUILERFL, post pics when you mount my bracket to my transom.   ;D ;D ;D
The custom aluminum bracket was done by A & J Marine Welding in Miami using a template of the transom curve we made - $1,600.00. Once completed, we place it against the transom using a forklift and marked the holes – check out this site for complete measuring and installation instructions: http://www.dadmarine.com/doc.htm
Will continue to post progress pictures. Check my gallery for new pictures.
thats a good site for measurements FL!!
I did the same as FL, We set up a platform got the bracket against the boat and marked to holes.
But sounds easier then it really is!! I guess it is easier if you have 3x3 individual washers on each bolt.
But I made a full bracket on the inside of the transom, there fore I had to get all the screws from the outside of bracket threw 1 hole then threw boat, then threw inside hole.
Was a PIA getting them all to match!! :-/ I thought this would be the strongest way!
Yep thats pretty much what mine looked like to begin!
But I had to do some re drilling as I was going, as I drilled straight in and the bracket on the inside seemed to be a hair higher then the out side bracket.
Thats were using 3X3 1/4 square washers come in, they give you more room to play then the whole thing that I have.
