V21 Fuel Tank Removal - questions
Yeah Bradford, not a problem to replace the pickup tube. I can do that but don't see much reason to replace it since this one looks fine, to me anyway.
Reminds me, there is a brass nipple on the end of the pickup for weight. Forgot about that.
no, the spring ran the whole length of the pickup tube. wish I had pic, would make it easier to show, sorry phat
think not really a spring but a coiled wire running the length of the pickup
when the spring was new, would it have been strong enough to keep the pickup on the bottom of the tank and all the way to the stern end? how about replacing the hose with rigid plastic fuel line. plumb it down and back.
it needs a brass screen on the end either way.
btw fuel + water can make a clear blob of material, looks like a jelly fish, not easily spotted in a tank.
Heavy brass fitting on the end of the pickup - not an issue reaching the back and staying put on the bottom. Pretty safe to say the spring has nothing to do with my problem since the symptom is the same before and after the spring.
There's no doubt some crap in the tank. Dumped last year's h2o sep in a jar and a good bit settled in the bottom.
May put a trash pump suction hose strainer on the end if I can find the right one to fit.
Hey guys, I replaced all of the fuel lines about 3 or 4 years ago and it has never happened again! I'm 99% sure the old line that runs from tank to motor was impacted by ethanol and was collapsing. The old fuel line was attached under the deck so I did not get to pull it out and check it - had to leave it in place.
Glad you brought it up Bgreene, hope this helps someone else!
