Transom Trim
When I replace my motor I'd like to replace the cap of the transom.  Has any one replace theirs and if so with what?  Thanks Billy Mac
Here's a photo of what I'd like to replace.
I don't have that piece but most are made from angle alum.
But you will not be able to duplcate the curve like that, you will have to piece it or cut it to bend it.
Whats wrong with the one you have?? Can't see any damage from the poic you showed?
If I were to remove my trim, I'd get some 4" tape (glass) and some epoxy. Remove the trim, sand the area, a lay up a few layers with the glass tape. That way the the seam is sealed better to water. Before starting I'd tape off the area in a straight line, then paint when finished.
Airslot
Airslot
There are some cracks in the plastic. I just thought that if the motor is removed I replace it. I know if it ain't broke don't fix it. Billy Mac ;D
here's how i fixed that 21 i'm doing it had Aluminum from factory but that gap under those covers is a spot that starts transom rot
Before
Had to do some epoxy and micro ballons repairs
Before Epoxy Primer
After sanding the hull for primer and primed the transom.
After
After the paint on the hull and transom
Before
Before Epoxy Primer
After
you can go to Lowes and buy Aluminum Angle  and cut to fit that's what i did on this boat installed with stainless screws.
ok cleared till Friday night i'm going Coastal to pick up another trailer don't you want a tandem Hammer come on down i'll give ya the great deal lol.
Mac you just want me to send my Girl there to fix your transom? she helped and did alot of the transom work on the 21 project she actually likes boat repairing.
