Started the transom replacement, pictures speak for themselves:
Its a 73 center console. I leveled the boat out. De-rigged and removed the console, rub rail, and unscrewed the cap. Lifted the cap, cut across the inner liner and separated the inner liner from the outer liner using a wonder bar. Pryed up on the flor and popped the inner liner up and out. The Transom is toast and I was able to remove most of it by hand, literally. Just got the epoxy resin and glass. Im gonna start laminating and will post more pics. After the transom then the stringers.
