Transducer replacement
What would I use to fill screw holes that will be under water. I'm installing my new FF and transd and paddle wheel. thanks Billy Mac ;D
small holes like that can be done a few ways.
#1 and best way, Formula 27, fill and sand, Marine Tex will also be fine!!
#2 Take a Golf T put in resin hamer into the hole, let dry, cut end off. Great to fix screw holes in deck also!
#3. 5200 will work fine. (make sure to put 5200 on new screws)
use what you have!! Marine tex is perfect if thats what you have on hand!! F27 is very were Boaters world, hardware stores ect ect..
Re: Transducer replacementt
Don't forget, immediately after applying two part epoxy such as Marine Tex, wet it (water or spit works best) and smooth out the repair to avoid lots of sanding.
It works great for screw holes in the deck and stuff! I have even used them in my house for worn door hinge holes, gule hammer cut rescrew works out great!!
Glad you guys like it!! Wish I could say I thught it up, but some one showed me like 12 years ago. ;) ;D
