I might get the opportunity to do some side by side comparisons with a friend that has the 200HO. They are quiet and smooth. His hull is a 21' Paramount center console. So far the V and the Paramount are surprisingly similar in top end numbers with the Paramount having 25 less ponies. Him running a Johnson 225 Fict and my running the 250 EFI.
Weight is a serious consideration. I switched from a 450 lb EFI to the 505 lb DFI in the same advertised hp and displacement and lost MPH. What I gained in economy was worth the move but the added weight hurt the balance.
He changed from the Fict to the E-tec and went from 225 to 200 hp. He claims the E-tec will run circles around his old motor even giving up hp. The big block E-tec is bound to have more torque but does it have enough to evercome the weight disadvantage? Based on what Kevin is telling me I think 5 to 7 mph. (If you can live with the weight) If I could trade today for a new 200 DFI or 4 stroke that only weighed 400 lbs I would get rid of the 505 lb monster in a heartbeat. Maybe the 175 Opti ? I think it is around 435lbs.
Genie full load of fuel and five passengers loaded for a day on the water I can touch 53.
First--200HO is 510lbs
200 is 418lbs
100lbs to small block
The 200HO is also 218 hp at the prop.
The speed difference should not be more then 5 to 7 mph I would think.
Question is --how fast do you want to go???
With mine loaded for tuna--means ice--alot-Fish hold full, gear, food, 30 gallon bait tank full of water, people and 70+ gallons of fuel with arch and stand up top--I can run 49+ agianst a good 15 knot head wind--Best I have seen is 53+ with the 200HO. Faster than I need to go most of the time on Saltwater. But it does cruise real easy at 35 to 40 and not even work with the heavy load.
Repower at 150 hours, WHAT?
Man, 150 hours they just starting to loosen up a bit and really run. You know teh old saying, they always run there best just before they go POP! So I always run the snot out of em, and when they REALLY run strong I worry.
In the long run, IMO the small block 200 Etec is gonna be your best buy...considering weight/horsepower of the motor itself and combination of that w/a V20 hull, it makes a nice long-haul package...![]()
200 is 418lbs
Rebel 15.25 x 19 SS
Just let the torque do the work.
