macojoe
Administrator
Ok I have everything hooked up and all is working, lights tilt & Trim, But the motor doesn't go??
I have fresh gas, I have ck'ed all plugs for spark and they all have it. Compression is 97 to 100 in all.
I pump the ball and ai have gas leaking from cause I pumped to much.
I have manualy gave it gas and watched the choke, but I think the auto choke at key is not working.
Now when I first started to run it I saw fo milky stuff coming from ther carbs?
I drained all the carb bowls, and changed out the filter (water seprator} and tryed again, tghe milky went away buity still no start?
So I have fresh gas,
I have spark,
I have good compression
I have gas in the carbs
motor turns over, but not as fast as th 175?
Now what?? :-/
I have spark,
Now what?? :-/
