The Motor won't start??
macojoe
Administrator
Ok I have everything hooked up and all is working, lights tilt & Trim, But the motor doesn't go??
I have fresh gas, I have ck'ed all plugs for spark and they all have it. Compression is 97 to 100 in all.
I pump the ball and ai have gas leaking from cause I pumped to much.
I have manualy gave it gas and watched the choke, but I think the auto choke at key is not working.
Now when I first started to run it I saw fo milky stuff coming from ther carbs?
I drained all the carb bowls, and changed out the filter (water seprator} and tryed again, tghe milky went away buity still no start?
So I have fresh gas,
I have spark,
I have good compression
I have gas in the carbs
motor turns over, but not as fast as th 175?
Now what?? :-/
Have you tried any of that starter spray? It sounds as you may have had some water mixed in the gas and that spray may be enough to get it to fire and burn off the water. If the choke is not working that would also keep it from starting.
Is there a safty kill switch on the engine?
Sorry, thats just something that would happen to me
Sean:
If Kill switch is not installed he won't have spark.
Isn't their a manul primer setting (red value) that would help prime it and get some good gas into the clyinders?
Kamiakze
Kamikaze is correct. There should be a small red valve just below the VRO and fuel pump. Turn that baby in the up position and it will serve as your choke. However, remember to turn it back once it starts...
I think MJ is home in his basement sulking. I've been trying to call and he won't answer the phone.
He's mad at me because I couldn't come help him today.
I mean, it's only my grandson's birthday so there shouldn't be any problem spending the whole day working on MJ's problems and blowing off the little guys B'day. Right MJ?
Ok tere are two winners here!! Well your all winners ;)
Stillrunning and Kamikaze!!
I moved the red thing amajig up and sprayed with starter spray, and BOOM!! she started right up and stayed running started right up everytime after that!
The Tac went to 2200 rpm's and stuck there? I guess I should have bought the gauges from the guy when he offered?
Well it idles pretty high, but I have the book here so I will look up how to adjust.
Thanks all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ;D
As for CB, whats the matter don't you like fat guys with no money?? :-[
MJ, did you remember to turn the red valve back to the down position? That will keep it at a high idle if left in the up position...
DON'T MAKE ANY ADJUSTMENTS WITH IT OUT OF THE WATER!!!!!
I CANNOT stress this enough! You can set your link and sync on it, but don't change the idle speed. Your used to your old cross-flow engine, that early looper will change drastically when it is put in the water. Timing needs to be set to 18 BTDC @ 5000RPM's, and your in gear idle should be around 650-750. If you don't believe me about the engine changing when you put it in the water, put a block of wood over prop and block it off while it is running.
Ferm is right. For this reason, I'm having my local neighborhood outboard mechanic meet me at the water this evening to adjust my idle...
wow I am glad you came on!!!!!!m mI was just going out the door!! :o
Also the guy said that he put a new water every January including this past one, but water comes out the tell tail slow, will that get better in the water also??
Thanks
I don't have a local guy that will meet me? I would have to pay thur the nose or do it myself. :-/
And CB is no help :'(
Perhaps you could get 'r' done by using some makeshift barrel/bucket or something to fill with water and lower the foot into so as to create some backpressure? You'd just have to be careful to give the prop clearance and keep the water coming into the barrel/bucket or whatever... It would have to be fairly large though...
I don't know; just a thought.
Have you removed the carb plugs and sprayed cleaner thru the holes?
Not running, high idle and shutting off could be slightly clogged jets
The loopers seem to flow alot of water through them, many times a hose won't supply enough enough volume. You may also have some debris in the tell tale spout. Another thing to consider is that alot of guys down here yank the T-stats out due to the high water temps. These engines are actually pretty easy to work on once you get aquainted with them.
Bygracealone Posted on: Today at 3:49pm
This time of year I have a bunch of ramps not in heavy use on the week days, so I can just dip it in the water on the traikler for that matter and do it.
tsubaki Posted on: Today at 3:50pm
The guy had the motor on the boat till the day it was shipped, so its been down for 2 weeks.
Will havingn it lay on its side for that long cause anything?
Be careful what you spray on those plastic carb bodies, carb cleaner WILL!!!! melt them(don't ask). You have to use very mild cleaners to clean them out. I like to use WD-40 and compressed air for just spraying them off(gas would work as well). OMC ENGINE TUNER is the only thing that I know of you can dip the carbs in to clean them.
I've seen these V-6 loopers idle at 2000, and then drop down to a 600 idle in the water. Back pressure is VERY crucial on a looper. Loopers flow more efficiently up high, and tend to produce more high rpm HP, whereas cross-flows pull extremely good down low. This is why many people were dissapointed with loopers when they first came out. There boats would rocket on plane with the C.F. engine but fall off up high, the loopers would struggle to get on plane but once they got on top would fly up high. This is why most small HP engines are C.F.'s. Don't pass judgement on the engine until you get it in the water.
Well removing carbs is not on the list of things to do! :o
I am sure if I take to the water like you say and add some new plugs and see what happens.
Do you use a old pulse car timer to time the outboard??
