You'd be surprised just how little that (the correct) foam does absorb, the average boat may be around 5 gallons.
The wrong foam will be as bad as a sponge. Can't remember which was which.
The usual problem is water trapped between the foam and it's way to drain.
I would bet that if you pulled your boat to Arizona and left it out in the desert for the summer, it would dry out.
I know it sounds crazy, but it is really dry out there.
