Starbrite hull cleaner.
Works great. Spray it on, wait a little and the yellow turns back to white. Galvanized trailer doesn't look the greatest. Spotted it all up.
I've never used it but good to know. Did you try wetting the trailer first? I don't know if it would help either way.
I used to use MaryKate hull cleaner. Close to the same stuff. Works great, but had to keep someone with the hose on the trailer and the concrete.
Great for getting rid of rust and scum lines.
My hull just was yellow. No rust so I can't say if it worked on rust. I tried purple power and simple green before and it did nothing.
When I had my boat I used On & Off - It was great - It took every thing off - Even those black rub marks - Back then it was an acid - The first time I used it I opened it up and smelled it - I almost passed out - Then I tried using a sponge - That lasted about 10 seconds before it just fell apart - Not sure if it still is - It burned holes in my shirts - The pictures are of me using it on Lloyd's V20Me carrying the acid.jpgMe putting on the acid.jpg
