Specs
Here's the finish after buffing.
Yeah, I don't know if the sun and moon got in sync or if the tide farted. ;D But seems fine now.
More to do,more to do,more to do.
They had painted over the mildew and stains instead of cleaning the gelcoat.
Once I remove the rest of the paint I can them clean and wax the gelcoat. It's proving slow.
I'm sure it seems slow, but at least everything's there...all windshield components and sliding hatch...some of the guys have been lookin' for that stuff for years ;)...
Once ya get all the old paint off, ya gonna go back w/new?...stock color?...
None or I should say the original. So far once I strip the paint, clean or watersand the gelcoat then buff with a coarse rubbing compound and then wax, the finish is reasonablly acceptable.
More and more getting tore out and refurbished.
Drained and removed the tanks during the week and today bought the stuff to refit.
Found out why one tank acted clogged.
Filter (now cleaned) and pickup tube full of trash.
The other tank is perfect.
As you can tell no great expense has been applied to most of this project. My initial goal is to get operational and then get a feel of what I might want to modify.
i have the same tanks, and had the same problem, I got rid of the ball in there years ago!!
If I could make a sugestion, On these old models they put the gas vents below the rub rail, well they all leak gas!!
When you fill up they will splash out, when you going down the road and stop gas comes splashing out all over!
This was a poor design!! and I am not alone, I have spoke with others that have had the same problem.
What I did was disconect the oringal and left in place as not to have to fix the hole.
Then added New 90* angle ones up higher on the Gunnel step up, Have never had another problem.
Keep up the good work!!
Like MJ, I moved mine above the rub-rail also...mine was takin' on water in turns in any kind of seas...you might wanna keep it as for now, but 1st time you get water in your gas or you see a trail of gas runnin' from them, you'll wanna make this change ;) ...
Thanks MJ an Reel. That's why I'm hesitant to made many changes at this point without having prior knowledge of problems to come.
When daddy had the boat, instead of replacing the stuff and cleaning the tanks he just used a surface tank, so I'm sure he is unaware of the vent problem.
Once I get it useable I'm sure to made other changes.
Oh on ya'lls fuel gauge(s), did you have one or two? I was going to try this anyway, mine had one gauge and a three position switch. Basically, left tank, off, right tank.
I had one gauge as you say, But they never worked right and I have no used a gauge in 8 years!
I just know now, I do a 30 mile round trip, and maybe another 10 or 20 moving around tyrying different spots and when they day is done I have used 15 to 18 gal gas.
Unless I went off shore, I have never used more then 1 tank of gas for the day.
I also have a 3rd tank I put were the I/O use to be before I converted, Thats total 65 gal.
I put two new gauges in for mine, but the single gauge/switch setup works great...just depends on what ya wanna do and how much room ya got... ;) ...
