Skool's V20 Rebuild starts
THEFERMANATOR said:
Might I ask why you chose to cut it out rather than seperate the cap and hull? I ask because mine needs a new floor and transom and I thought it would be easier to just seperate the two rather than section it out.
If you have that much repair work it would be much easier to take the boat apart. That what I did.
lol new location for outboards lol mine only needed a floor so no need to go to the trouble of the cap removal, i hope to ask $5000 for the boat turn key when finished, depends on how much it takes to get right.
Can't wait to see finished "V" 8) ...
SKOOL, you whats the next step on the floor. Will you cut pieces of plywood to fit the shape of the floor skin, then resin each piece to the deck.
Keep going, dont stop. ;)
Skools...looks like a smaller tank forward of the main ... whazzat ??? ...
When ya put new floor back in, do ya put a lip under the outter edge to catch?...
What is the deal with WellCraft and these little 6x6 pieces of wood they use. The only thing I could think of is they have a slight gap between them and the resin runs between them. If one gets water in it the others have a little protection from the resin between them. By changing to 3/4 wood won't that make it a little tougher to complete the flooring.
Well.....is it done yet SKOOL. ;D
Where's the Pics. Bro. Dont wanna hear no excuse's that you were sleeping. You never Sleep. ;D ;D
These old guys never read!! Just look at the pictures!!
i'm going to remove the extra tank inthe boat it has a 60 gal and an added 25 gal, i'm taking out the 25 and going to add foam to the hull in all the voids to add floation
since i'm working on the 230 Sea Ox, so the V is on a temp hold, but almost done with the 230C, well the 1/2 to 3/4 will be fine i'm filling the gap around the edge and will make a channel on the sides to run the water off the deck. i may curve the floor to run the water to the sides too.
Sounds like your getting fancy. You could name the boat
"Schools Fancy" "V Fancy" or "Well Fancy"
