Skool's V20 Rebuild starts
My 140 4stroke works great on my cuddy. With light fuel and load I get 40 mph, 37 mph loaded up w/ gear, gas, people. But it turns 6000 rpm, might not get the same w/ a 2 poker.
micro Balloons are brown usually and are little air pockets that allow you to sand resin like bondo, it actually makes the resin weaker lol but makes it very easy to sand, just makes water proof bondo lol.
Hey Skools,
When you filled in the bigger holes with wood, resin, and glass, did you put anything on the backside (like tape) in order to keep the resin from pouring through the other side through the voids?
Also, did you use any sort of filler or wood before glassin over the holes for the snaps?
Great work as always maestro ;)
taped the back side of the holes with masking and filled up with resin then glassed over larger holes and the small ones just grind out and then glass and resin over the hole and the fill with resin and micro balloons
Hey, no pics. Was expecting to see pics. of teh gel coat going on. LOL.
OOPS, I gues I shouldnt say much. I have alot to do as well.
But then again, we do expect alot out of ya SKOOL. ;) :P
here's the v20 sitting outside after the 21 issue
i'll cure it soon lol
here's some for Hammer the Sea Ray  ;D
there's the spare parts from the V20 and the Dixie.
My Sea Ox is currently holding all the rubrail and bow rail. If anyone is interested i'll sell them just make offer.
well i've finished my V and now shes sea foam green and white top see here below the hard top cost more than the boat and made her longer some.
"MOVE" on down brother you can come over and we'll build all sorts a stuff, Get BR and Frayed here it will be a true Boat repair party. ;D
