Rhodes lifters?
rotella!
I would use rollers if you can find me a cam to suitjust get roller lifters... done and done
I think pretty much any cam will work w rollers..... just can't use a roller specific cam w non roller lifters...
Aren't you having a cam reground... could you not specify that it be a roller cam?
i look at that the distrubtor gear would be a problem so i think that's outHey Aussie, has any one laid that 3.7 cam beside a 460 cam? Wonder if you could run a 460 cam on only use half the lobes? You'd have to bore the end of the cam to accept the shaft for the water pump though.
