Removed my deck
the deck is all in and ready for glass.
I did away with the step down in the deck area, I felt it was treacherous for the kids.
I re used the floor boxes,that was quite a bit of work to make them fit back in nicely and be create a strong mount.
sorry to tell you but i think the original work was far better
let me explain
if one part was bad you can take out a square plus the parkay floor( i no i miss spelled that] could have been sanded and you can dance on it with a little polyurathane it would have looked great now its going to look like a boat before a dance floor it makes you think,,,,what were they thinking when they did that to such a great boat
Looking great Liam. :clap: :clap:
Absolutely fantastic work.
Looks great! I hate the step down too, what were they thinking? And Wellcraft isn't the only manufacturer who did them that way.
thanks for all the kind words,
It sure does feel good to be walking on a deck again instead of crawling around in the bottom of the hull.
I think it was Skools who said the small squares with the alternating grain actually made the deck stronger.
I would think this would have to be the case vs the ease of just glassing a couple of large sheets of ply. Even if they were getting the ply wood scraps for free I don't think they would be saving.
When you get water intrusion from a screw hole in parquet it ruins 1 square. When you get water intrusion from a screw hole in a sheet of plywood it eventually ruins the whole sheet.
X2 When I redid the underside of my deck on my V21 I used as much scrap plywood as I could find, for that very reason. (I was counseled by my friend that owns a marina and knows these sort of things). His advice was pretty much what Skunk just said.. don't use full sheets, use pieces instead, as it will be stronger and last longer. And don't forget...SEAL the underside before you button it up, and VENT it with hatches open when it's stored.
I understand the theory of using multiple squares but thats only possible if you have an intact surface to lay them out on,my deck had already had the center section removed by a previous owner to allow a poor stringer fix,or if you pull the whole cap and turn it upside down.
I would also imagine you would need around 3-4 extra gallons of resin if you construct the deck in that manner.
I sealed the underside of my sheeting with resin and 3/4 oz CSM.
Looking good. While the small square theory is sound, there is nothing wrong with whole sheets, especially in resto situations where there is no backing to lay the squares. As long add the under side is sealed with CSM you'll be good to go.
Actually, you don't want to use squares. or even rectangular pieces. Irregular pieces work best. The idea is to not have any parallel running seams like you would get with same sided pieces. That way there's no weak spots, I know we're getting picky, but the very best way is curved pieces, (like the curves in the letter "S"). They are the strongest.
Here is the glassed in Deck. I had to build up the saddle tank platforms due to the raise in deck height,to prevent water sitting under the tanks per the original design.
It needs a little sanding here and there and then fairing.
thanks guys.
phatdaddy,I wish i could get her wet but i still have plenty more work.
The boat is going to get a full repaint.It will next season before she hits the water again..... hopefully lol
Its been way too long since I updated this thread but the boat is almost finished. here are some pics.
We are moving to North Carolina next month and the boat will be coming along.
