fixed vane impellers don't suck well, just like my pool pump. You have to have a head pressure to get it to pump. Sliding vane impellers work well, but they don't like any kind of contaminant. the one I use for waste oil get stuck up all the time with particulates that get by my 10 micron filter. Gear pumps require too much lubrication and don't make enough volume. roots type pumps move a lot of volumes, but take a lot of horsepower to operate. I squash plate type pump runs too critical clearances adn would cost too much to implement. Enter the floppy vane impeller, moves enough volume, makes enough pressure, is tolerable to running to dry to an extent, able to self prime, very forgiving in tolerances. Cheap to make, easy to repair, works through out a wide variety or rpm ranges. SO why not?
Next we enter the housing aspect. Mercury used to use a small diameter stiff blade impeller in a plastic housing with a stainless sleve. Very good pump, but don't let it sit still for a long time and absolutely don't run it dry, even for 10 seconds. It will ruin everything. OMC large diameter floppy vane, low pressure, high volume. Stainless sleeve in a plastic housing. Run it dry long enough and it will melt the plastic housing. Does OK. Yamaha copied the same design but with a few differences, same issues. Suzuki stepped up with a cast stainless steel housing on the same type of impeller, you can smoke three or four impellers and the housing don't care, but run it in enough sand adn you'll be crying about how much that housing cost. Enter Mercury for round two, large diameter floppy vane with a stamped stainless housing, cheap to make, just as resilient as the zuki,easy to replace. Mercury wins with teh best design water pump assembly. BTW, I probably replace 100-150 impellers a year. I/O and Inboard pumps are a whole nother subject
