Destroyer
God
Why do outboard engines use rubber impellers? They constantly wear out, can cause serious overheating problems and can foul up your entire cooling system if they break apart.
I have 2 British Seagull outboard engines, and they don't use a flexible impeller. They use a solid impeller just like you would expect to find in any car or sump pump. So a solid impeller can be used... So WHY do the outboard makers continue to use rubber impellers?
(And before anyone says anything about pressure or volume, let me remind you that a 1 1/2 hp sump pump running at 1725 rpm has a head of over 20 feet in a 1 inch discharge. That means it can pump a column of water 20 feet straight up.
That's more than enough pressure and flow for any outboard engine).
