Uhh, Hammer, the pulpit is 1.5" thick, why 3" bolts? The roller bolts don't go through the deck, or do they? I can't tell where everything falls, cause I don't have mine yet, sniff, sniff
To much overtime. Just home now from working the night shift. I need to stay out of the evidence room.
I used 2" inch bolts that just fit. Go with 2 1/2 if you want some of the bolt to slightly stick through the lock nut.
I made my pulpit out of 1 1/4" teak, about 36" long and 12" wide. It will hold all 215 pounds of me hanging off the tip of it sitting on dry land. Very tough. Pics follow here:
I have to remove it soon to refinish it. That's the only downside to using the teak, I'll get more up after the job is done.
Played at the city shop for awhile with the plasma cutter again. ;D
Little bit of grinding to make her purdy. ;D
I hate these damm fish rod holders. I would love to yank them out and put a sheet of starboard all the way across. Then add hatch covers to gain access. Before screwing them back in, I ran to more power lines for the future. In case if I ever install a stero and something else on that side of the boat.
The big hold up !!! Something so stupid, but couldnt go any farther. I need somebody up top while I break the bolts free from the underside. Nobody around to help, so It didnt get done.
MJ, I noticed you have the round deck pipe, the same as AIRSLOT, but the thimble at the end of his anchor rope wont fit through as he posted. Did you have the same problem or does your fit ??
If you have the same problem as AID did, I might go with teh rectangle one like Phats has.
