Ok Merc issues
Will do!! I changed all plugs today, so they are all new now, they were a bit oily and looked old?
This is a response I got from Iboats. I explained all just like I have done here, but I think this guy is wrong as I had this issue long before I went trolling for Tuna. I am going again by th way Wednesday!!
You simply have an oil overload.
When this occurs again, immediately pull the plugs and take a hard look at them. I'd be willing to bet that they are seriously oiled to the point that they will NOT fire under a heavy load such as put on the motor at 4500 RPM.
There is also an amount of pure oil in the recirc system, patiently waiting for engine speed to increase sufficiently to get it airborne and burnt off and let the spark plugs burn clean enough for the engine to get up to full power again.
The factory oiling systems lighten the oil mixture at low engine speeds to prevent this oil overload and hesitant throttle after long periods of idling and/or trolling.
Possible cures are;
1. install a small trolling motor and NOT idle the big motor
2. install spark plugs one-step hotter than the factory specified plugs (also, if piston clearance is adequate, change from surface gap to standard electrode or extended electrode plug)
3. if carb'd, readjust idle mixture to leanest idle possible and still not have any hesitation on rapid acceleration in gear.
MJ - I thought you hadn't run the boat since we went out around wings neck. There were two lil' hicups on take off, but it never hesitated or lost power during the 2 hour run (after we replaced the stator) . . . unless you dropped some roofies in my soda :) and missed something. I anxiously waiting for tomorrow update. Hope all goes well . . . if the Tuna are around . . . I going out this weekend.
Those plugs you showed me today were dripping two stroke motor oil :)
BS you smoking anything??
I just told you I caught a Tuna last wed, and that I went for a ride in the boat Sunday, so how could the last time I took the boat out be in July with you??
He needs to open the door to the shop when he's test running those motors. Breathing too many fumes.
Hey now, that 2 stroke smoke be good stuff.
I am leaving here at 4am, I can't wait!! A guy I know went today and they caught another 150 ponder out there today!
Also yesterday on the Chatam side they caught a 1200 ponder!!!! They say the big ones have been close and that there is at least five 700 ponders this past week!
Well the bad news first, 6 footers out there wind and waves in are face, after 2 miles turned around and came back in, NO Tuna :cen:
Good news, came in and went out in a different area, drove boat about 15 miles at about 5000 rpm doing any were from 25 to 29 knots Opened it up and topped out at 33 knots, Motor never missed a beat!! Could have trimmed it a bit more and got another mile an hour??
So after putting new plugs, new ck vaule in the fuel pump, and redirecting the supply hoses to the carbs, it works! Not sure what fixed it??
Redistricting the fuel hose was like this, it had one supply hose from the pump, across the motor to the other side and that one hose went to top carb, then from there each carb feed off the one above.
Now there is a 3 way on the pump and a hose going to each carb direct.
So was it the hoses?? Ck Vale? plugs? or a combination of?
But it works!! Thanks all and to BS for stopping by to help me out!
I am 99% sure I know what was wrong, but as soon as I open my big mouth . . . I'll probably jinx the motor. Basically I believe that it wasn't getting enough fuel at high rpm.
The hose from the merc male plug to the fuel pump is 1/4" ID and it was kinked a bit by a tie wrap. I put that tie wrap on to keep the hose away from the linkage (when it was near full advance). Anyways . . . to make a long story short . . . I had MJ working the throttle while I was watching the linkage near the hose. 1 out of every 5 times the throttle was advanced to near WOT the linkage bumped the hose and kinked it (cutting off the fuel). I rerouted the fuel lines and fittings to the carbs with a old school three way fuel pump nipple. I pulled apart the fuel pump just to look for any shaving on the filter screen and replaced one of the check valves that wasn't very snappy. The motor seems to have like the changes, so I'm happy that MJ's happy and the boat is running well.
I'm pretty sure that's this will one of the final chapters in the MJ motor fiasco series. Well change the poppet valve and rebuild the carbs in the spring . . . just to be safe :)
MJ - I plugged the numbers into the prop calc and your right on the money 5600 - 5800 rpms to get that speed with 2:1 ratio, 15p prop and 12 -15% slip. All you need now is a good tach or an adjustment on that one.
I need a new one. Also have to get the temp gauge working and a few other small things. We will get there!!
Thanks
Did you put a 2:1 on it BS? I thought all of the 2.4L's and 2.5L's were the 1.87:1's?
