G
golver1
Guest
Ok, new problem. I just put in a new ignition. I verified several times that I matched the 3 posts (Battery, Ignition, and Solonoid) on the old ignition with the new one. I then moved the wires over one at a time, post by post. I had to switch because the key for the old ignition was lost.
Problem: Nothing works. I turn the key and nothing happens. No light, no gauges, no starter, no power tilt, nothing. I verified the battery has power. I was also able to verify the nav lights work by rigging a + and - to the battery directly.
The only wires I could find disconnected was a thick black one that that comes from behind the motor (similar, but slightly smaller then the ground cable off the battery) and a small purple wire on the side of the motor near a bunch of other wires. I connected the purple wire to a bolt sticking out that some other wire was on and a red light started buzzing loudly on the dash, so I removed it. I then connected the black wire to the ground of the battery, reconnected the purple wire to the same bolt, but this time no buzz. Still no power to anything.
Please help. Boot has not run since it was winterized.
Does anyone have the wiring schematics for a 81 V20?
