well had trans issues so here's a few pics
forgot a keeper which was good so i could find a couple other issues
well opened it up to find more issues so i opened the spare trans and made one great trans with 2 good trans
here's a cracked axle
here's the spare trans this morning
a must a home made spacer from a piece of starboard off a boat
don't forget to remove this ring clip or you will tear up the drive seal
both trans opened
spare trans inside
old trans opened again
found the reverse drive to be missing the clip that held the bearing in and it was letting the drive rub the pto when in reverse
old trans parts
reverse drive rod eat as well
clip replaced finally
only to find the clutch lining loose on one side so will fix while it's apart
here's a easy way to put the case back and line up the keyed gear to the forward drive
grease key in gear
put grease in the forward drive plate and insert gear
here's the gear and key greased and ready to go back together
new trans painted and installed on frame
old trans open new one installed
closed old trans to keep out weather
new trans mounted and motor as well
next the new tires and rims to be installed
