macojoe
Administrator
http://capecod.craigslist.org/bpo/5117683513.html
list of what I have. Aug 1 2015
Send me your real email if you expect a response!
Lots of other items for sale or trade.
Also have Antiques, Boating Items, Fishing & Hunting items, Tools and Toys for sale.
FOR SALE:
This is a list of what I have. Trying clean out the house to move somewhere warmer.
a whole bunch of mostly new parts that fit outboard motors.
Some for inboards and some diesel parts also have a few parts that are in good used fresh water condition.
Southern, Maine
Can ship smaller items if you pay postage.
New Hazelett Elastic Yacht Mooring system,Never Used.
designed to hold up to 50 ft boat. Includes Bouy, Dual Elastics, Shackles, Swivel & Painter Rhode.
I sold my boat and never used this.
Just hook it up to your Granite/Concrete Block or mushroom or helical.
Buy my new unused one for just $995. Cash
3 Water Pump Impellers Teleflex 18-3056 Impeller - Dia. 3 1/2"",Dpth. 1 1/4"" - 6 Fins Neoprene Honda # 06192-ZW1-00 Fits Honda 75HP and Merc 4743026-2 and others. $15. ea.
4 Johnson/Evinrude Stainless Steel Steering arms for outboards (may fit other brands) $25 ea.
1 Johnson/Evinrude Tilt Pins retainer Bars for Johnson/Evinrudes (may fit other brands) $5.ea.
1 Johnson/Evinrude Rectifier/Regulator Kit #CD4 583110 9GR-0A $50.
1 Johnson/Evinrude Ignition Coil Kit # 583737 $30 ea.
2 Johnson/Evinrude Ignition coils # 0A $10 ea.
2 Johnson/Evinrude POWER PACKS OMC CD4 584027 $5 ea.
1 Johnson/Evinrude Voltage Regulator Kit # 173640 Just $100.
2 Johnson/Evinrude Timer Base Kit #583376 $100 ea.
1 Johnson/Evinrude Water Pump Impellers for 85-150 HP $10
1 Johnson/Evinrude Complete Water Pump kit HP #391391 $40
1 Johnson/Evinrude CompleteWater Pump kit for 85-150 HP Part # $40
2 Johnson/Evinrude Evinrude Johnson 3" Tach & System Check Gauge.$120 ea.
2 Johnson/Evinrude Trim Indicator Gages $50 ea.
1 Johnson/Evinrude lower unit Gasket #286279-2 $10
2 Johnson/Evinrude Rubber Exhaust Gaskets fit 85 to 150 HP V4 motors $5 ea.
6 Johnson/Evinrude Gaskets # 317914 fit 85 to 150 HP V4 motors $5 ea.
1 Johnson/Evinrude Gasket # 359-317955-1 $5
9 Johnson/Evinrude Gaskets # 194-321727-1 $5 ea.
1 Johnson/Evinrude Gasket # 436-323459-1 $5 ea..
5 Johnson/Evinrude Gasket # ? $5
2 Johnson/Evinrude VRO Oil hose & level Sender. $75 ea.
1 Johnson/Evinrude Alum TRIM TAB 327640 OMC $10
1 Johnson/Evinrude Zinc Skeg trim tab $10
3 Johnson/Evinrude #323664 Spline Gear $25 ea.
1 Johnson/Evinrude drive shaft 85 to 150HP $50
1 Johnson/Evinrude Clutch dog OEM #22683 OEM #319895 $50
2 Johnson/Evinrude Helical Lower unit Gear sets # 340490 $50 set
4 Johnson/Evinrude 90HP-150HP Rod Bearings set $40 set
2 Rubber Exhaust Gaskets $5
1 Complete 90 Hp Gasket set # 139300 $40
2 used OMC Stator #583669, #583672, $20 ea.
2 used JOHNSON/ Evinrude Stator #583669, #583672, $20 ea.
2 Johnson/Evinrude fuel fittings $5 ea.
1 Johnson/Evinrude set of plastic engine throttle connector slides $5
1 Johnson/Evinrude used VRO Oil Tank with hose & level Sender. used $75
1 Fuel Fittings Set male & Female old style Merc $10
1 Fuel Fitting Honda $5
1 Fuel Fitting Suuzki $5
8 Teleflex Black 8ft t shift/throttle cables OMC $25 each.
1 Teleflex Black 15ft t shift/throttle cable OMC, Johnson/Evinrude $10.
3 Teleflex Black 12ft t shift/throttle cables Merc/Mariner $10 ea.
4 Teleflex Black 16ft t shift/throttle cables Merc/Mariner ea. $25. each.
1 Teleflex Black 23 ft shift/throttle cable MERC $30.
1 Teleflex Black plastic steering wheel $10
1 remote steering Alum Bracket for the Merc/Force 9.9 or 15HP outboard motor.(May fit other brands) $100.
1 Plastic Pitot Tube just $5
2 Battery Rotary Switches used just $10 ea.
2 Aqua Power Impeller JP 28948-001OMC #509182 Fits Jabsco Seawater pumps Used just $10.ea
1 pair of Standard Battery to Engine Cables Used$25
2 Johnson/Evinrude electric fuel chokes Used $25 ea.
1 Johnson/Evinrude 90 hp Carburator Used $20.
1 Timer Base Kit #583376 Used$30.
1 Johnson/Evinrude Rectifier Blue Power pack no part # Used$30
1 Johnson/Evinrude Rectifier/Regulator # CD4 #583336 23IM-0A Black Rectangle Used $75.
1 Johnson/Evinrude Rectifier/Regulator #5114-04 DT-4 G Alum Metal Rectangle 3 wires? Used $30.
1 Johnson/Evinrude Rectifier/Regulator # 395391 Used $50.
1 Johnson/Evinrude pt/pt Relay Box with Cable Used $50.
1 Recoil Starter Assembly for Merc/Force 9.9 or 15HP outboard motor. Used $30
4 Tilt Pins retainer Bars for Johnson/Evinrudes Used $10 ea.
2 Stainless Steel Steering arms for outboards Used $25 ea.
2 Stainless Steel Steering Coupler brackets Used $25 ea.
2 Johnson/Evinrude Ignition coils # 0A Used $50
1 Johnson/Evinrude OMC Stator #583672 Used $50
1 Johnson/Evinrude OMC Stator #583669, Used $50
4 Johnson/Evinrude ignition coils Used $10 ea.
2 Johnson/Evinrude Flywheel Used $40 ea.
1 Johnson/Evinrud Shift/Throttle control Housing, missing a couple parts Used $20.
3 Johnson/Evinrude TRIM TAB (adjusts outboard torque) 327640 Used $10 ea.
4 Johnson/Evinrude Big heavy Alum wedge Motor Mounting Brackets to shim up outboard on transom Used $25 ea. All 4 for just $90.
1 Johnson/Evinrude plastic throttle shift handle with pt/pt switch Used $10
1 Johnson/Evinrude plastic throttle handle. Used $10
2 Johnson/Evinrude Tachometer used Used $10 Ea.
3 Retainer Pins for the Engine Tilt Used. Just $5. Ea.
1 LOWRANCE Blue water Pro Flasher/Paper chart recorder Fish finder with transducer. Used $150.
1 RAYNAV 520 Loran with coupler Used $40
1 Apelco handheld GPS 15 with dashboard mounting bracket Used $50
1 Raytheon VHF/TV Antenna Dome Used $40
2 High Flyer RADAR dual Bouys, Alum poles Used $100. For both
10 Brand Valves for Inflatable Boats. $20. ea.
1 ONAN Generator control panel Just $50.
1 ONAN Temp Gage #129-8739: AK21LB23 $50
1 ONAN Temp Sender #7E-4279 : AK 25EB33 $30
1 Adaptor # 9M-6522 : FITAM26 $6
1 TEE # 033-2177 : FITDP08 $20
1 Bronze 11/2 Prop Nut Used $5
1 Fuel Fittings Set male & Female old style Merc Used $10
4 Teleflex Black 12ft t shift/throttle cable Merc/Mariner Used $10 Ea.
1 pair of Alum/Plastic oars for inflateable boat Used $10
20 Heavy Battery #2/0 Cables 2 ft long with ring lugs Each used never seen water Just $10
1 Factory Service Manual Johnson/Evenrude Outboards 2 to 150 HP models for 1980's & 1990's Just $25 .
Raytheon Marine Electronics Factory Service Marine set of 2 Used $10
2 Alum Dingy Davit Brackets ( 2pcs mount on transom & 2 pieces mount on dingy)
$200 pair
Chevy/GMC 5.7ltr Serpentine Belt. $15
Bosch Fuel Filter In tank fuel filter for Chevy/GMC z71. $4 In tank fuel check valve for Chevy/GMC z71. $4 Chevy/GMC K1500 rear brake spring kit. $5 Chevy/GMC Clutch or Brake Pedal Rubber Pad $2 Fuel filter Chevy 350 $4
ACCELL High Voltage Ignition Coil $50.
Felpro Chevy 305/350 4 boat rubber valve cover gaskets 1 pair PN# VS12869R $10.
NEA. PN# VS2335 Chevy 305/350 4 boat Marine Exhaust Manifold gaskets.1 pair . $10.
Felpro Mercrusier Chevy 305/350 Gasket kit assorted not complete (head gasket missing) $10
1 Chilton Repair Manual Subaru Used $5
1 pair KLH Large size indoor/Outdoor waterproof speakers used Just $50.
1 pair KLH Medium size indoor/Outdoor waterproof speakers used Just $30.
1 pair Advent MARBL II W NEW unused in box Just $100. Pair
Great Rack to carry of Canoes, Kayaks, Small Boats, Construction Equipment , Lumber and other items. Custom Made one of a kind Marine Alum Anodized Welded pickup truck Racks, Length 8 ft between front and back stack pockets is 93" width between stake pockets is 69" center to center mounting.) Removable rear Pipe to carry high cargo. If you have a shorter bed on your truck you could cut the Alum pipes to size!They are built somewhat like a Tuna Tower is made. new ones run around $1,500. from Marine welders. Not too many companies making them. These are one of a kind, I had a welder make them to fit my Dodge Ram Quad Cab but the size will fit most any brand full size pickup truck. I did find some similar ones advertised at some Marine Welder in Virginia for $1,495. plus $250. shipping but his do not have a removable rear bar like my racks. There was another builder somewhere up in the pacific Northwest that makes them. The thought of mounting the racks on my Center Console boat came to mind but I already have a hard top on it.
These Racks are used but in great condition. Just $695.
New Dodge Ram 8 lug 17 inch New Hub Caps! Just $65. for both of them.
2 Amber Strobe Lights. Just $95. pair
Pair of Sears, Five Star 3,000 pound capacity, 7 Ft Alum Arched Ramps Cost $438.34, These have been used once. Just $225.
5 each Purolator F56097 Fuel Filter Just $15. ea.
1 each AFE Fuel Filter #44-FF003 Just $15.
(Buy all 6 Fuel Filters for $85!)
New unused Dorman Diesel Fuel Filter Cap Just $15.
Used Dodge Cummins 5.9 lift pump. Works. $20.
Used Dodge Cummins 5.9 ITS Sensor Works. $20.
2 ea. Onan Fuel filters Part 149-1494-05 $75. for both.
1 ea. Onan Oil filter Part 122-0827 Just $10.
1 ea. Racor R20s 2 Micron Element Just $20.
2 motorcycle levers and a Red taillight lens for Yamaha RD 250-350 models or others $30. pair
2 Oil filters for Yamaha XS1100 Just $20 for both
used Horn with bracket from Yamaha XS1100. Just $45.
Chevy check valve for in tank high pressure fuel systems $10.
Polaris ATV Brush Guard Back Never used. Just $25.
do NOT contact me with unsolicited services or offers
FOR SALE:
Southern, Maine
$200 pair
