Livorsi fuel sending units
Blu_Lunch
My boat didn't have a fuel gauge so while the tank was out I tested the sending unit and the gauge worked fine. So I installed the gauge and when I put 30 gallons of fuel it should have gave me a liitle more than a 1/2 of a tank, but when I turned on the key it was less than a 1/8, I checked everything I even reached in with a piece of wire and grabbed the float and the gauge went up. I got POed and pulled the sending unit out and found out the unit is 5 inches short. So off to the boat parts suppler and found out elbows types only run to 27 inches. The guy recommended this Livorsi type sender that measures  air pressure in a small tube so there is no floating or bouncing gauge, has anybody here have one....Ted     http://www.livorsi.com/catalog/waterproof.htm
Looks good. But never heard of them??
Juast be like me, I have none for all the reasons you are trying to fix!
MJ sorry to hear about your OB troubles I lost #2 cylinder on my Johnson last year on the first trip. I never heard of Livorsi myself but after looking thru the cataloge WOW nice chit, what is really nice is the dashboard gallery This stuff is OEM on a lot of the finest high performace boats....
Thanks for the tip. I have ordered the Livorsi unit it should be here tommorrow the Centriod unit is simular to the one I bought... My CC tank is 32 inches deep..Ted
