HOLY CRAP ! ! ! ! ! !
oh yeah and keep the paint yopu are removing wet with the stripper if it sits vewry long you will have wasted time cause it dry's up and the paint hardens back up, just keep wet with stripper and strip in about 10 to 15 min and use sharpened puddy knife or razor blade
ok stinky poopy, i started painting it today.
the primer websight says just use a light dusting but the guy at freeport marine said two coats so i fugured, if a little is good then too much is fantastic.
when that set a bit i shot on a coat of enamel to seal it up.
tomorrow i will shoot it with an underwater primer and finally a coat of antifouling 3 million dollar spraypaint.
then i will spend 42 thousand dollars on zincs and cross my fingers.
barring an act of god i should be in the water by friday.
With all the new environmental laws you can't buy that good paint remover that they made 10 years or so ago. I had some stuff that would make the can it was in swell and then shrink the can as the temperature would change. That stuff would have the paint falling off after about 15 min. this stuff now days I think is almost safe enough to drink.
