HELP!!! (FOR MY FRIEND).
hey guys, my buddy has a 95 or 96 v21 with a 96 johnson ocean runner.
he says that he tops out at 4400 rpm. this does not sound right to me.
also says he thinks hes getting less than 35 mph.
says that hes buning a sh!tload of gas.
running out at about 4000 rpm.
WHAT GIVES?
what does he need to do?
being an I/O guy, the only thing i can think is he is an impropper propper.
any help will be passed along to him.
WHAT GIVES?
What's the hp of the Ocean Runner?  Sounds like prop, unless he's not running on all cylinders. If he can, let us know what pitch prop he's running.
Like Seacrets, need to know HP...then need to know Max recommended RPMs by mfgr and a working tachometer...assumin' everything Ok w/ motor, he should be able to sustain mfgr's max rpms @ WOT...flat water, no wind, light load and trimmed up til she ''suckin' ducks!"...
Sounds like he's off on prop and probably needs something like a 3-blade 15 1/4'' dia. x 17 or 19 pitch...recommend SS...w/ mild cup...
Let us know ;) ...
Let us know ;) ...
I run a 150 hp with a 17" pitch prop. , 1.87:1 ratio and I turn 5500 RPM.  When we get his prop pitch and diameter we can solve this. He'll probably bun less fuel too. ;)
44.7 mph on gps with a 4 blade stainless. I could probably pickup 2-3 mph w/ three blade prop. 2000 Merc Saltwater running 5500 rpm.
My old 86 150 Merc would hit 41 mph with the same prop.
