Fishing trip pics
  • Thread starter Thread starter lucky_strike
  • Start date Start date
L
lucky_strike
Guest
Yesterday my son and I went out to the tire reef, 3 miles off
Barnegat inlet for a day of fluke fishing. Turned out that the
fluke action was from slow to nothing. While making a move
inbetween drifts, we just happened upon a school of hungry
bluefish that were jumping and swirling on the surface. Since we wern't catching any fluke, we decided to switch rigs and go for the blues. After about an hour of fast and furious action we had a dozen in the box and had lost about a half dozen more due to straightened hooks, ripped open snapswivels, and broken lines. Big blues are real tackle busters. We knew that we couldn't utilize more than a dozen bluefish so we left them biting, called it a day and went in early. Also while we were in the middle of catching blues, we saw a pod of porposes swimming nearby. Maybe they were catching bluefish too. We didn't
catch any fluke, but it was a great day out on the water, and the boat performed flawlessly.
It just isn't working, Ill have to get back to this when I figure out whats wrong.
Hey lucky - you get an "A" for effort! The first one did load correctly. Is that a blue being reeled in or a porpoise fin?
I can smell the salt :-*
Thats a blue on the end of the line close to the boat.
The blues ranged in size from 8 to 12 lbs.
Right now I can't get any pics to post at all. Later tonight
I'll try from my home computer and see if that makes any
difference.
[IMG]http://i3.photobucket.coRe: Fishing trip pics
Trying to post pics again using a different computer.
I still can't make it work; the pics are there in "photobucket", but I can't get them to transfer to this site. What does it mean when you get the red "X" where the pic should be?
Hey Lucky, at the bottom of each pic in photobucket you will see three boxes. The bottom one is labeled IMG. Just put your cursor on the info until it is highlighted. Then right click and select "copy". Then come back to your reply message in V20 site, right click and select "paste" in your text box. This should allow you to post the pics. Just hit submit. To do multiple pics, hit the enter button in between the above directions. This is how I do it. Hope it helps. We want to see the pics!
LS...are yor pics in a "SUB-FILE" in PhotoBucket?...when I first tried to post pics from PB, I unknowingly put them in a sub-file and was gettin' pretty much same result you're gettin'...they gotta be in the FIRST file you get to in PB...hope this helps... ;D...
