THEFERMANATOR
God
You check for voltage to ground from the stator first, if any is found then the stator is bad. Then you check the peak voltage coming out of the charge coils(stator), 150 is minumum for your app at cranking speed to the packs(with packs disconnected). Then you'll need a PL-88 to install in place of the coils, and you should have 130 volts minumum there. If you have 150 going in, but less than 130 coming out you'll most likely need a new pack. The next test is for the trigger coil, they should produce 0.4V at cranking speed. Obviously this is much easier with a book in front of you outlining which connectors to check. If you can't find a true PRV meter for testing magnetos, then your best bet is to swap the packs from side to side. It shouldn't take but 10-15 minutes to swap them, and if the problem follows the pack then replace that pack. You can also buy a CDI 511-9773 and use a standard DVOM(digital, not analog). The OMC tool isn't expensive, but it's tough to come by. The CDI adapter lists for $90, but can normally be found for $45 online(unless you need it ASAP, like I did).
