Deck repair
Well for the 7000 post here, this is what I did today.
Worked into the dark, in the cold and the rain trying to get the deck done.
Framing in some supports, checked the wiring and added in a new fuel line. Glue and foam.
Screwed and glued in the new wood. I wet the wood down with West System the day before.
Tearing, and scraping off the old wet wood.
Skin all cleaned up.
Wet down the skin and the wood. Then the rain started coming down harder.  >:(
Threw down some wax paper and tossed on some old batteries and anything else I could find.
Next will be to grind down the sides and add in some cloth. Not to worried on appearance. Gonna spray the deck with WHITE bedliner rubber stuff.  ;)
Held off on cutting out the access hatch. Thinking of going with a bigger one.
why did you not cut the access hole out before you glued it down?
Have to be care full when cutting it now!!
