Finally, got some cousins to help install the bracket. Created a template out of 1/2 ply and got the bracket installed.
Haven't done the filling of the gaps like MJ did yet.
We had some discussion with an engineer cousing of mine which claims that after reviewing the bracket, the center section is held by 12 bolts and 5/8" aluminum on the bracket. Hence he believes that the side sections which are only 1/4 or so aluminum are not there for structural strenght. He thinks it's better to not drill any more holes in the transom and leave the gap. At most if I fill the gap with PT wood, to not put through bolts.
Any comments are accepted. I am leaning to think it should be ok without filling in the gap considering that most brackets hold the motor with just the center section. Additionally, i'm not going to pull anyting with the side pieces. At most it will have 200 lbs. on it or so when someone is getting in or out.
One thing which I didn't have readily available but we are looking to get a hold of is a few pieces of aluminum to put under the bolts on the inside to distribute the force.
