Boyesen Reeds Installation Question
Engine 1987 140 V4 Looper
I have a question, Do I disregard the four parts on the left of this photo and use the two on the right per Boyesen instructions ?
The parts on the left is the stock parts
When you run the BOYESENS you take the origanl thin metal reeds out, and also the thick metal plates which were the factory reed stops. You use the new 2 piece reeds with the smaller reed on top of the one with holes in it and use the brass metal strips and the screws that came with the BOYESENS. Also make sure to use red loctite on the screws when ou put them in as they will see ALOT of vibration.
