I have the made in China winches on my trailer. They have been used and abused literally hundreds of times over the past few years. Especially with Sandy clean up. They are 9000 lb truck winches with a dedicated battery mounted on the trailer charged by the truck thru a quick connect. That is probably overkill for a V. But earlier this year I installed some Harbor Freight ATV winches to one of the trailers at work. Even though it is rated for 5000lbs I was skeptical. But they work great. I have already moved at least 40 boats with them without problem. They are quiet,fast and cheap.
Destroyer,
I'm not trying to pick apart your post. I have used the Powerwinch and the LD winches before. And for my personal use they were insufficient. Slow,noisey and expensive. For the occasional recreational use they are fine. In my opinion I have found the vehicle winches to be better. I would love to put a $1000 Warn winch on my trailer but it's not in the budget for me.
Destroyer,
Question could be - what about for salt water use ?
Are winches meant for vehicles going to stand up to cranking in a salt water covered cable.
Corrosion being the issue.
I called Superwinch Company, and they advised that their open style winches likely to corrode, and that their cable is also just galvanized.
Power equipment will never last as long. Armstrong will last your lifetime!![]()
Doesn't anybody else drive their boat on the trailer? No need for a power winch to crank up a foot of cable.
I drive mine on with or without someone. My boat is small now but I done it with my 18 Wellcraft too. Back down drive it up, lean over bow and hook it or hop off and hook it and winch the last couple feet. Leave the motor running and in gear when you get down. Simple.
The way I launch is very quick......... using the stem of the trailer, and the bow line set in a triangle around the bow cleats. Anyway, I wrap the line on the trailer stem, then let the boat just roll off the rollers in a slow controlled release by taking a loop off the line till it starts to slip.
Several times a season I hear " wow, you must have done this a few times" ...........
It's the cranking back up where I could use a power winch because I don't submerge my trailer wheels......the rear axle water only to just below the hub if possible.
Sure I can still crank a boat up no problemo, but there are hot days when I'd rather push a button !!
