Bygracealone
God
BGAlone,
The SP 5101 or 02 are both great, and not expensive. There are other brands also good but SP I have installed many and they are simply a standard on quality and price. The 6db gain SP are all good. The more expensive ones have better looking finish and looks, but are electrically similar. S.P. normally come with the connector NOT installed, to allow you to easily route the thin coax via a small hole. Installing the COAX connector ( CB type PL-259 ) is NOT easy, you will need a GOOD and powerfull solder iron or gun, so the HAM radio guy idea is what you want, besides, they are ALL great and very friendly guys/gals.
An 8' AM/FM is OK if you want more range, and that way you will match both sides and the boat will look even, that is what I have, but if you have strong local stations for FM, you won`t need a big AM/FM antenna. With my 8' FM antenna I can receive St. Thomas stations which play AWESOME Reggae music, from 40+ miles away, with a shorty one, that will not be possible for me.
JJ, have you ever seen these? I think they're new and were probably made because of the many complaints people have made about the difficulty of installing the connector:
http://shakespeare-marine.com/connectorshow.asp?menupick=pl-259-cp-g
Do you think this will do the trick?
