Still preparing boat for the water, and now that motor is running, moved on to other areas.
Expected to find a bilge pump, but after removing round metal cover, was surprised to find no bilge pump. Seemed like most of the area had foam in it, and it looks factory. Only a small area for air leading to transom plug.
Hull has two scuppers, but nowhere on the outside of the hull could I find where a bilge might have exited.
Reading the posts here, and this does not seem correct for a '72. Is it because it is a CC, and most bilge related posts were for the cuddy? Were all the CC's built this way, or has the boat perhaps been modified?
http://www.wellcraftv20.com/gallery/view_photo.php?full=1&set_albumName=album104&id=P1010005
If you look closely at transom picture you can see right scupper. To the right of scupper are two holes, one for tank vent and other for console filler vent. Also, tank vent line runs through battery box, where it has a "T" that vents off the starboard side.
Maybe someone has seen the boat before when it was used (stored for last 15 years). Looks like name "Fish Story" was on the side, and purchased from Ft Lauderdale area.
