spareparts
they've been running electric oil pumps on optis for quite some time now. If you disconnect your engine while running, you're going to burn up some electronics as well. Just don't disconnect it
http://www.propelledmarine.com/oil_injection.htm
$400, pricey, but a lot better than tearing down the engine & putting it back together.
with another plastic gear.
nice info , capt pete
I figured out which terminal in the harness shut it off.
Motor sound really good. I think i might have upset some neighbors running it at 10:00 at night.
Put a thread on the local forum to see what some of the dealers can do on a package deal for rigging. As for a prop i have a Rapture 14.25x21. I am thinking its too much pitch.
It had a tee in the water outlet hose that i assume was for water pressure. Should i keep it or just plug it?
As for maintenance i have already replaced the spark plugs, and i plan to change the lower unit oil and water pump, then clean the carbs. Still wondering about the oil injection.
Destroyer if you decide to run premix i can take that oil injection off your hands.![]()
I believe the EOI uses the old oil pump.
What we need is a boat mounted 50:1 premix unit. Something that you pour your oil into, and it mixes the oil with the gas at a 50:1 rate, then pours it into a remote 5 gallon fuel tank, which the fuel is then drawn out of by the outboard. The remote 5 gallon tank serves as a backup in case, the unit fails you dont immediately burn your engine up.
Maybe i should patent this idea???
from what I understand, it's not the oil pump that is the weak link, it's the plastic gear on the crank.
I don't think you can patent just an idea. You have to have a drawing of the unit showing how it works I believe. Still, it's a great idea. Something that would automatically sense when your gas didn't have oil in it and would automatically switch over to the reserve tank of premix. Think of how many hundreds of thousands of dollars in ruined engines would be saved. Still, maybe we shouldn't think too hard about this... It might cut down on Spares and Ferms business... that would be bad for them. (But I love the idea of the automix tank)
I am stuck right now on this idea. I need an investor and somebody good with "electric stuff"
