2000 Boston Whaler - 23' Outrage
SOLD SOLD SOLD SOLD SOLD SOLD
2000 Boston Whaler 23' Outrage Considering trades and/or offers.
2000 225 Optimax 30" Shaft Engine hours 418 as of 8/1/11 Small chip in the skeg.
Continental Tandem Axle Trailer - Galvanized Steel With one year old radial tires (approx 2000 miles) new hubs 5/7/11 Very roadworthy and setup for easy loading and unloading. New Galvanized Trailer Jack 1500 lb capacity with drop leg 7/15/11
STILL for sale. Honestly, $22,000 will buy it. Make that $21,000 Needs TO GO...
The boat features:
T-top with New Electronics box, 4-GOLD Annodized rocket launchers and storage for life preservers and such overhead
Rupp outriggers built into T-top
Stainless Leaning post/seat with storage under seat and flip down footrest.
94 QT Igloo fits under leaning post facing aft 3 or 4 years old, good as new and stayes in place with two bungee cords
One round livewell With New Bait net
Two rodholders on gunnels per side Nice polished stainless variety with "Whaler" cast right in the mounting flange on every one and all have liners to protect the gear.
Three more across the European transom
Rod storage on both sides under combing pad Deck brush on one side, Gaff on the other and go with the boat
Transom door on Starboard side With fancy latch for keeping it closed or a hasp to hold it open allowing access to the aft deck where there is a
Telescoping swim ladder
Two in floor fish boxes w/pumpout Gulper style pump that is mildly effective on pumping the boxes out.
Large insulated storage in front casting deck Used to ice fish down with overboard drain or carry valuables as it has a lockable latch. Dry storage.
Flip up seat in front of console With removable cushion that snaps in place.
Flip out transom bench seat With removable cushion
Head in console w/macerator pump (broken because it was never used)
Custom snap down Cushion for raised casting deck up front Converts the casting deck into a lounge area for sitting or laying down.
Bimini top covering the foredeck Provides shade for anyone choosing to sit in front.
Full boat cover that snaps to the underside of rubrail Has not been used in 8 months because I have been showing the boat
Full combing pad around cockpit All upholstry intact just showing some age.(slight staining and a little sun damage)
Fresh water shower Should be mandatory on every boat. 13 gallon water tank with pump and built-in pressure switch
Raw water washdown With coil hose and non marring nozzle. Whaler uses a Y-valve so the same pump that provides raw water also provides water to the livewell. Water scoop on bottom of hull ensures the pump will always keep a prime
Courtesy lights One in the head, One red/white dome light mounted to underside of T-top, Two cockpit lights under gunnels. One light in the livewell. All operate off independent switches
Electric Horn
All Switches are Lighted when on Mil Spec CONTURA switches by Carlingswitch and are protected by circuit breakers with waterproof boots and manual reset.
All welded stainless steel bowrail Starts at the console and carries thru to the tip of the bow pulpit
Bow pulpit
Bennett Trim Tabs
Battery Switch w/ two batteries New as of 7/14/11
Bilge pump With automatic switch and manual override
Bilge pump in a sump under console With automatic switch and manual override
Hydraulic Steering w/tilting helm Resealed steering cylinder in June 2010.
Mercury Binnacle controls
Mercury Smart Guages Tells engine hours, RPM in digital or anolog, trolling feature to be able to control the exact RPM for speed of troll by push button, barometer, block temp, water pressure, trim angle, boat speed with paddle wheel mounted on transom, battery voltage, fuel gauge, oil gauge, instantaneous MPG, average MPG, Trip Meter, and instantaneous range based on fuel and speed. The LCD display on the gauge will also tell you if a sensor has failed and can help diagnosis of engine problems.
160 gal fuel capacity Aluminum tank with dual pickups from factory
225 Optimax serviced 7/15/11 Water pump, Gear Lube, Greased Prop Shaft, New Trim Sensor, Plugged in to check Computer With No Faults Detected Used for a week in the Florida Keys logging over 150 miles and ran flawless(Pushes the rig about 44mph max. Cruises low 30's while delivering 3MPG Average)
982 Garmin Color Chartplotter/Fishfinder Not a big screen but the mapping helps makes anyone a navigator. Depth finder is adequate for the average fisherman. The GPS is intuitive and easy to use for tide information, time, routes and waypoints are easily stored and named. It comes loaded with coastal charts from Texas to Maine but does not have any lakes or rivers. It is upgradeable by chip and NMEA compatable.
VHF Mounted in the overhead electronics box that is rigged wth power and has room for more electronics 8' antenna with Stainless Steel ratchet mount
Sony AM/FM CD (i-pod hookup) 4-Speakers A pair of West Marine 6x9 with 2 year warranty and a pair of Bose 301's 4' antenna with Stainless Steel ratchet mount
Compass Flush mount atop the console
Trailer has recently been refurbished with all new springs, (Springs now have a light coating of rust) new bunks and Kodiak stailess steel brakes.
Rope locker up front with gas shock to hold in the up or down position.
7 Polished Stailess Steel Cleats Two in the back with hawse pipe, two midship, two at the bow and one centerline in the Rope Locker.
Includes USCG safety equipment New handheld flare kit good til 2014, signal mirror, signal flag, throwable cushion, five runabout type life vests (yellow and blue) fire extinguisher with recessed mount at rear of console and a anchor with 200 ft of rode. Four dock lines in black. Gelcoat is still in good shape. Very sound. Hull is rock solid.
Nice rig Ready for action $21,000 Bottom never painted. Fresh wax job.8/1/11
Thanks, you ain't alone. I waited too long to list it but I don't need 3 boats anymore. This is a nice rig. They are crazy expensive, New. Tell a friend.LOL.. Thanks for looking.
We just put 8 hours on the Whaler this past weekend. She is running great. I discovered the rope that lashes the canvas to the T-top was getting kinda rotten. It will be fresh and new for the new owner. In black this time.
Bump with a lowered price. Plan on using it over Thanksgiving. I prefer to sell it whole but if you don't like the Opti motor, buy it without and repower with your motor(s) of preference. The fuel tank has the extra fuel pickup for twins if desired. I can use the Opti on the Wellcraft and more than double my range over the current EFI 250. This Whaler is rated for single or twins to 300hp. Thanks for looking..
Nice boat, hope she sells for you my friend.
Tell me Ridge, why does she need a 30" shaft on her Opti? Looks like a standard transom height?
The boat has a 30" transom. Motor is mounted to the transom like normal. Lots of freeboard. Some of these were rigged with twins, twins used 25" motors.
I hope it sells soon. Peak of the season is here. Going to run an ad on Boat Trader. There are about five of these boats on there now, all more $$$. This one is prime for the taking. Not saying it is the nicest one but it is one of those boats that will be around in another 20 years IMO. And thanks Willy.
I have two worthless checks in hand from scammers off Craigslist. I need to re-up there too. I don't have it in front of enough potential buyers is part of the problem. I have it at a consignment lot with 20,000 cars a day going by it every day, a few people interested, but not interested enough. Someone paid for a survey that turned out well but the gent was from upstate NY and shipping was $1700 and the potential buyer stopped returning my e-mails. I am tired of cleaning and waxing the boat every so often. I wash it three times and use it once, it has a full cover but it is hard to show with the cover on it.
Updated with some blue commentary and a new price. $21,000. Willing to seperate boat motor and trailer. It needs a new home folks.. Just put another 500 smackers into maintenance and incidentals. My back is still hurting from all the waxing and polishing. It is Slinger Clean and ready for a change of address. In a month or two I intend to start replacing the upholstry and the price will go back up. Noticed some cracks in the starbd side floor box hatch today. I paid to have both hatches recored in 2008. It is solid but will need some attention at some point as that is how the original hatches began to deteriorate. The fix was a couple hundred for both versus a new lid from Whaler at $400 each.
THANKS FOR LOOKING.
At the risk of an 8 page diatribe on what the price should be. I would like to see this boat gone. $21,000 and a full tank of non-ethanol 91 grade. A $640 value. Another cleaning on 10/1. Lots of activity but still avail. Engine hours are now at 425.
I love the thought of being down to 2 boats. It is tempting tho.... Your V catches fish, :sun::beer:
Continuous Wave, got it Phat. I hear you about attitude. I have not posted it in too many places, Whaler Mall, CL Tampa and here. If it were a 70's or 80's model Outrage it would already be gone. The Whaler purist dislike this hull. It is more of a deep V design with a small brow.
No fewer than a dozen folks couldn't get financing. I am being told the boat appraisal from the bank came back just north of $25,000. Hull alone $16,000. The banks seem to want 20% down. Last deal fell thru at $23,700 after tax, customer had 10% down and a credit score of 680 and the bank said no. Still have one guy interested, his loan is approved but he works 14 hours a day?? I dunno what to make of him time will tell..
ridge, have you tried posting on continous wave. lots of attitude over there, but they are nuts for whalers
I'm with ya Phat. I'd probably like whalers more if so many of their owners weren't douchebags.
Same goes for Georgia football.
Best of luck with the sale Ridge, seems like a really nice one. It sucks trying to sell stuff these days.
Thanks for the remarks, it is a nice boat. Not all Whaler owners are douchebags Bradford, (excluding me, naturally). Let the diatribe begin... LOL!
You realize that by painting Whaler owners in a negative light, that you just ran off all my potential buyers. I mean who would want to own one now? Knowing from the jump that if they buy it they will be forever known as a douchebag? Now I will be forced to give it away at a reduced price in this economy and well, ain't life a biotch?
You know I am just kidding around.. It is what it is. And the Continuous Wave Forum is kinda brutal at times. If I wanted to be crushed on a forum I can list a few more that get ugly at times.. :beer:
Hey bro... at least I didn't call it PRICEY!!!! LOL!!!!
Not all whaler owners are douchebags, especially not you or Phatdaddy!
But think about it, here you have this excellent well maintained boat that you are selling for less than value and a forum that is dedicated to the same brand of boat turns their nose up at it. God forbid you tell them you like a McKee Craft. As I get older I have less and less tolerance for a holes who think some how they are better than the rest of humanity.
That being said, anyone in the market for a high quality example of a well thought of brand of boat should highly consider Ridgerunner's 23' outrage. In fact, it is the only whaler currently on the market that Bradford on WellcraftV20.com won't think you're a douchebag for buying.
