steplift20
God
I was in the back bay buy Sayreville or keyport, not to sure of the exact location I saw another steplift out there with a Yamaha engine Was it any of you guys?
:ski:... but the impeller hasn't been changed in about three years Maybe longer
:ski:
That's a part that needs to be changed when its good.
What I'm going to do first is take out the thermostats then run thr motor, if it has a water stream then I know it's the thermostats not the impeller , what do you guys think about that?
change the impeller....even if its good, you need to remove those bolts every year or 2 before they seize.
I know its painful to throw away a perfectly good impeller but it has to be done.
When you get a $25 oil change at 5k miles you throw away perfectly good oil....
just change the T stats while its apart...what maybe $50 a pair, why waste time boiling them... and they'll have new gaskets.
