1988 Evinrude 225 experts needed!
  • Thread starter Thread starter yankiwi
  • Start date Start date
Y
yankiwi
Guest
A few questions guys,
I'm looking at a V20 CC powered by a 1988 Evinrude 225. It has a very recent "new" powerhead, plugs, wires, pumps etc.
So...
Good motors overall? I asked a local mechanic and he said they are strong, but thirsty... sound right?
Is this probably a "looper" engine?
Any other info on this engine would be appreciated. I am sure it will have plenty of go on a V, but I am not as interested in speed as I am reliability and some economy. Any idea on what the motor should be worth? NADA is $900 but the recent work is obviously not included in that estimate.
Thanks guys, alot of questions I know ;D
I have a 1994 Johnson which is probably not much different as far as technology as the 1988. Mine has been pretty much trouble free and I think I have spent about 1,250 on the engine and alot of that was a carb job. Do you know if a carb job was done when a new power head was put on? Clogged carbs are the down fall of most engines as they run lean and burn up the cyl. I would test the compression and if thats reads good then you should be fine and if a carb. job was not done do that before you do anything else.
Great motor i have 6 of them. not all 88's but the 1988 block to the present E-Tec is the same block just bore and stroke. great motor and they are a little thirsty but great power and just test the compression the factory on an 88 to 91 was 90 to 95 PSI  per cylinder. Yes that is a looper V6 motor. good luck any more info needed just ask me and welcome aboard  ;D
Schools Out it sounds as if you know something about these engines. I have a 1994 150 johnson what should mine test at and what did they run when it was new? Thanks
Thanks Skool's, I read some of your previous posts just now. Seem's like a great motor.
Just to be sure when I look at it. An 88 should be a 3.0 liter big bore right? If it happens to be a 2.7 then its an 87 correct?
Also can anybody ballpark what this motor, with new powerhead, is worth? I'm trying to come up with a reasonable offer for the boat and need some guidelines.
Thanks guys.
I've got a freshly rebuilt '90 model, runs like a champ. I've got a cuddy cabin which has a little more weight, but it hauls a$$. A CC model should move even faster if set up right. Fuel consumption isn't too bad as long as you're not throttle happy.
Correct that should be a 3.0 at least
the small bore has 3.500 pistons which were in all pre 1988 loopers and big bore have 3.685 bore in 1988 up looper 120,130,140,200,225,250,275,300 hp motors
V-4 Models
1.6-liter Crossflow, 1983-1987, and 1988-1990
1.8-liter Looper, 1985-1987
2.0-liter Looper, 1988-1990
V-6 Models
2.5-liter Crossflow, 1983-1990
2.6-liter Crossflow, 1983-1990
2.7-liter Looper, 1985-1987
3.0-liter Looper, 1988-1990
V-8 Models
3.6-liter Looper, 1985-1987
4.0-liter Looper, 1988-1990
the 2.7 was a small bore and has either 200 or 225 HP depends on what carbs you have and jets. do the carb butterfly's have 2 or 3 screws holding them in? 2 will be 200 Hp carbs and 3 will be 225 Hp carbs.
the bore change from small to big was basically done to improve idiling charistics, also other modifications were done after the change mostly carburation i think there were 2 or 3 diff. carb configurations in one year in some of the preceding big bore models, but all that was mostly concerned with idle and intermediate circuitry. they all (200/225 LOOPERS) thrashed around at idle a bit till the later models when they finally got it right, but all ran great at W.O.T. old and new were great motors,
but they did like there FUEL and hated to run lean at W.O.T. also keep an eye on the flywheel magnets factory glue tended to come loose, the magnets would shuffle around inside, a new flywheel is close to 1000 bucks now, but we usually can rebuild them for under 200, the prob with used big motors is if you can afford the big boat there on and the fuel to run them you can usually afford to buy a new motor, so there usually a hard sell for any kind of good money,
want to try something fun try a big block E-tech we took an old pair of 225 loopers off and installed a pair of 250's the change was phenominal.
it doesn't cost $200 to rebuild the flywheels i have several and rebuilt several. they usually cost $9.00 for the epoxy to rebuild them. i have a tube of the epoxy and have used same tube for the last 10 or 12. Those motors still bring good money for their age. the E-Tec is the same block as the old loopers just new heads and intake.
I have to agree that they are excellent motors and while thirsty, they seem to run forever if you keep the gas clean which is not an easy thing to do with todays crap gas...I compare them to the old merc 150 tower of power that sucked gas but are still running today if you keep clean fuel in them...I currently have two old johnny 225's but have had several johnnyrude 225's over the years and I think they are a great design and very simple motors to understand and work on..even for someone like me who can only do basic maintenance...I'm a firm believer in the KISS system (Keep It Simple Stupid)...I've also had a state of the art super charged fuel sipping ultra tech outboard that blew up the first year and twice the second year so I now try to search out the old 2 stroke low hour KISS motors that guys are trading out for the new high dollar and high tech wonders that no one can f###### work on..Frank
evinrudes are good engine I just sold a 1988 23' Wellcraft with seadrive 225 on it (evinrude are great). I have not noticed them using any more gas then anything else. Unless you fish everyday it probably won't make a big difference.
6 months ago I sold a 1984 evinrude 70 hp that had never been rebuilt and still ran great. The boat was falling apart but the motor was great.
Premix and it will run for years.
I do think that a 225 is a lot of motor for a V20.
I just mentioned the Merc auto-oiler in another thread...to me, same goes for OMC motors...disco the oiler and run forever 8) ...
Why did the 225s have trouble at idle ? This is the trouble I am having right now with a 87 OMC, wont run on it own under 3000 rpms without hitting the primer to keep it going
